>>> Join Us in the Fight Against Air Pollution
Resolving Inaccurate PM Sensor Readings in AirGradient Devices
I’ve noticed several posts here discussing issues with the PM2.5, PM1, and PM10 sensors in some AirGradient devices, while the PM0.3 sensor appears to be working fine or at least more accurately. My readings for PM2.5, PM1, and PM10 are almost always zero, which seems to be a common issue for many users. However, I’ve observed that the readings increase when I cook and my device is near the kitchen, and also when I blow out a candle—the PM readings spike after extinguishing the flame, indicating that the sensors are responsive to something. Aside from these events, my readings usually stay at zero. Is the issue then a problem accuracy or are the sensor responding to something independent of PM?
I’m trying to understand how this problem can be resolved and whether the sensors are fine or not. I saw a comment today suggesting that it might be due to a calibration issue at the factory. For those of us experiencing these inaccurate sensor readings, what’s the solution? Do we need to replace the sensors, or is this something that could be fixed through a software update or calibration?
This is the most current information:
Low Readings from Plantower PMS5003
Low Readings from Plantower PMS5003 - AirGradient Blog - AirGradient Forum
The blog post that @MallocArray shared explains a lot but let me underline that this issue has top priority right now and many people at AirGradient are working on it.
I am confident we will have more information this week.
Hi Achim & Team AirGradient,
Any update on this issue? I have exactly the same problem with my AirGradient Indoor monitor installed recently as Kristjan describes. Constantly zero measurements on the PM2,5 , PM1 and PM 10 sensors while the PM 0,3 sensor is recording varying counts displayed in a nice graph. And if I blow a bit of smoke from a candle all PM sensors peak and then shortly thereafter back to zero.
My outdoor sensor seems however to be fine and records detailed and varying graphs for all PM categories.
Do you expect a sensor replacement or can this issue be fixed with updated firmware or similar ?
Looking forward to your feedback!
Thanks,
Andy from Sweden
We are on a very good track and yesterday our scientists confirmed that we can use the count to accurately recalibrate all batches that were affected.
We aim to roll this out this week.
You can read details and updates here:
https://forum.airgradient.com/t/low-readings-from-plantower-pms5003/2796/11
May I ask, does the firmware update happen automatically or do I need to do that myself, if so, how?
Thanks,
Kristján
If you are using stock firmware, it will automatically update once they release it to your device
