2025-02-09 13:08:01 pm02Compensated: 948.89
2025-02-09 13:08:04 pm02Compensated: 1136.21
2025-02-09 13:08:07 pm02Compensated: 1264.21
2025-02-09 13:08:10 pm02Compensated: 1334.69
2025-02-09 13:08:13 pm02Compensated: 1279.43
2025-02-09 13:08:16 pm02Compensated: 1087.97
2025-02-09 13:08:20 pm02Compensated: 980.06
2025-02-09 13:08:23 pm02Compensated: 771.77
2025-02-09 13:08:26 pm02Compensated: 681.78
2025-02-09 13:08:29 pm02Compensated: 526.86
2025-02-09 13:08:32 pm02Compensated: 459.74
2025-02-09 13:08:35 pm02Compensated: 340.83
2025-02-09 13:08:38 pm02Compensated: 293.2
2025-02-09 13:08:41 pm02Compensated: 200.2
2025-02-09 13:08:44 pm02Compensated: 162.82
2025-02-09 13:08:47 pm02Compensated: 123.25
2025-02-09 13:08:50 pm02Compensated: 107.01
2025-02-09 13:08:53 pm02Compensated: 81.47
2025-02-09 13:08:56 pm02Compensated: 62.87
2025-02-09 13:08:59 pm02Compensated: 55.92
And just to make sure my point is clear and concise. These are “micro bursts”. It is a feature that, in its current form, we can detect them…not a bug. I would be sad if you guys chose to smooth out the data even more at the firmware level.
For my usecase, however, I just do not need to know that they are happening. That’s why I think its best to handle this externally, where my usecase is defined.
Also I just need to say how much I respect you guys. If I am understanding this correctly…We are talking about a device that shoots a laser beam at a wall and extrapolates the volumetric density of microscopic particles based on how much light is blocked. And this device costs less than 20 dollars. Its a wonder it works at all.
EDIT
It seems the AirGradient Dashboard is applying even more smoothing than I am, probably as a result of the differing sample times and sample rates, but I’m not sure.
It gives me a value of 140 whereas I am getting a value of 250. This does not mean good things for HomeAssistant users.
Added some debugging for now to make sure I’m not wrong. Math seems to all check out
=== DEBUG: pm02Compensated Samples and Calculation ===
Collected Samples (Timestamp and Value):
2025-02-10T09:40:28.102332: 2.83
2025-02-10T09:40:31.135864: 4.93
2025-02-10T09:40:34.204736: 14.1
2025-02-10T09:40:37.284114: 28.86
2025-02-10T09:40:40.352671: 89.91
2025-02-10T09:40:43.454977: 128.16
2025-02-10T09:40:46.493462: 256.44
2025-02-10T09:40:49.566585: 319.75
2025-02-10T09:40:52.585304: 415.06
2025-02-10T09:40:55.718626: 444.41
2025-02-10T09:40:58.778988: 461.91
2025-02-10T09:41:01.851754: 472.83
Processing 12 numeric samples:
Sorted Values: [2.83, 4.93, 14.1, 28.86, 89.91, 128.16, 256.44, 319.75, 415.06, 444.41, 461.91, 472.83]
Trimming highest and lowest: [4.93, 14.1, 28.86, 89.91, 128.16, 256.44, 319.75, 415.06, 444.41, 461.91]
Average: 216.353 => Rounded: 216.35
Final pm02Compensated value stored: 216.35
Data logged at 2025-02-10T09:42:05.134554
2025-02-10T09:41:28.102435: 106.01
2025-02-10T09:41:31.140995: 92.78
2025-02-10T09:41:34.211874: 70.12
2025-02-10T09:41:37.285647: 53.75
2025-02-10T09:41:40.353161: 47.85
2025-02-10T09:41:43.530414: 37.98
2025-02-10T09:41:46.611290: 33.14
2025-02-10T09:41:49.695130: 25.99
2025-02-10T09:41:52.750837: 22.77
2025-02-10T09:41:55.820521: 19.62
2025-02-10T09:41:58.904748: 15.32
2025-02-10T09:42:02.062187: 13.57
Sorted Values: [13.57, 15.32, 19.62, 22.77, 25.99, 33.14, 37.98, 47.85, 53.75, 70.12, 92.78, 106.01]
Trimming highest and lowest: [15.32, 19.62, 22.77, 25.99, 33.14, 37.98, 47.85, 53.75, 70.12, 92.78]
Average: 41.931999999999995 => Rounded: 41.93
Final pm02Compensated value stored: 41.93
Data logged at 2025-02-10T09:43:04.936802
2025-02-10T09:42:28.102523: 3.53
2025-02-10T09:42:31.151005: 3.1
2025-02-10T09:42:34.234413: 2.92
2025-02-10T09:42:37.287007: 0.0
2025-02-10T09:42:40.364770: 0.0
2025-02-10T09:42:43.446056: 0.0
2025-02-10T09:42:46.526924: 0.0
2025-02-10T09:42:49.577013: 0.0
2025-02-10T09:42:52.659340: 0.0
2025-02-10T09:42:55.720521: 0.0
2025-02-10T09:42:58.794124: 0.0
2025-02-10T09:43:01.868487: 0.0
Sorted Values: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 2.92, 3.1, 3.53]
Trimming highest and lowest: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 2.92, 3.1]
Average: 0.602 => Rounded: 0.6
Final pm02Compensated value stored: 0.6
Data logged at 2025-02-10T09:44:05.053475
2025-02-10T09:43:28.102607: 0.0
2025-02-10T09:43:31.156735: 0.0
2025-02-10T09:43:34.234893: 6.06
2025-02-10T09:43:37.319414: 14.44
2025-02-10T09:43:40.366756: 90.54
2025-02-10T09:43:43.440058: 157.62
2025-02-10T09:43:46.535286: 473.8
2025-02-10T09:43:49.585015: 673.89
2025-02-10T09:43:52.654873: 1096.99
2025-02-10T09:43:55.728116: 1247.96
2025-02-10T09:43:58.798272: 1328.62
2025-02-10T09:44:01.847002: 1277.57
Sorted Values: [0.0, 0.0, 6.06, 14.44, 90.54, 157.62, 473.8, 673.89, 1096.99, 1247.96, 1277.57, 1328.62]
Trimming highest and lowest: [0.0, 6.06, 14.44, 90.54, 157.62, 473.8, 673.89, 1096.99, 1247.96, 1277.57]
Average: 503.887 => Rounded: 503.89
Final pm02Compensated value stored: 503.89
Data logged at 2025-02-10T09:45:05.063191
2025-02-10T09:44:28.102687: 156.47
2025-02-10T09:44:31.159884: 135.9
2025-02-10T09:44:34.239025: 101.97
2025-02-10T09:44:37.302389: 88.08
2025-02-10T09:44:40.374135: 65.68
2025-02-10T09:44:43.460625: 57.56
2025-02-10T09:44:46.535438: 45.63
2025-02-10T09:44:49.590963: 35.09
2025-02-10T09:44:52.670750: 30.46
2025-02-10T09:44:55.749919: 21.75
2025-02-10T09:44:58.805345: 18.3
2025-02-10T09:45:01.980746: 16.55
Sorted Values: [16.55, 18.3, 21.75, 30.46, 35.09, 45.63, 57.56, 65.68, 88.08, 101.97, 135.9, 156.47]
Trimming highest and lowest: [18.3, 21.75, 30.46, 35.09, 45.63, 57.56, 65.68, 88.08, 101.97, 135.9]
Average: 60.041999999999994 => Rounded: 60.04
Final pm02Compensated value stored: 60.04
Data logged at 2025-02-10T09:46:04.906214
2025-02-10T09:45:28.102805: 31.06
2025-02-10T09:45:31.162322: 92.0
2025-02-10T09:45:34.257449: 126.97
2025-02-10T09:45:37.313573: 192.26
2025-02-10T09:45:40.378747: 222.16
2025-02-10T09:45:43.461488: 220.22
2025-02-10T09:45:46.528455: 197.24
2025-02-10T09:45:49.597348: 154.23
2025-02-10T09:45:52.670155: 137.33
2025-02-10T09:45:55.757070: 108.64
2025-02-10T09:45:58.826523: 95.28
2025-02-10T09:46:01.888249: 83.36
Sorted Values: [31.06, 83.36, 92.0, 95.28, 108.64, 126.97, 137.33, 154.23, 192.26, 197.24, 220.22, 222.16]
Trimming highest and lowest: [83.36, 92.0, 95.28, 108.64, 126.97, 137.33, 154.23, 192.26, 197.24, 220.22]
Average: 140.753 => Rounded: 140.75
Final pm02Compensated value stored: 140.75
Here’s how it behaves with lower values too
2025-02-10T09:51:28.103418: 2.94
2025-02-10T09:51:31.205576: 2.86
2025-02-10T09:51:34.275515: 2.86
2025-02-10T09:51:37.357718: 2.86
2025-02-10T09:51:40.418564: 2.77
2025-02-10T09:51:43.490516: 0.0
2025-02-10T09:51:46.580327: 0.0
2025-02-10T09:51:49.636483: 0.0
2025-02-10T09:51:52.911827: 0.0
2025-02-10T09:51:55.984531: 0.0
2025-02-10T09:51:59.073359: 0.0
2025-02-10T09:52:02.229144: 0.0
Sorted Values: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 2.77, 2.86, 2.86, 2.86, 2.94]
Trimming highest and lowest: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 2.77, 2.86, 2.86, 2.86]
Average: 1.135 => Rounded: 1.14
Final pm02Compensated value stored: 1.14
Data logged at 2025-02-10T09:53:05.003288
2025-02-10T09:52:28.103525: 0.0
2025-02-10T09:52:31.209501: 0.0
2025-02-10T09:52:34.280547: 0.0
2025-02-10T09:52:37.359848: 0.0
2025-02-10T09:52:40.425278: 0.0
2025-02-10T09:52:43.513907: 0.0
2025-02-10T09:52:46.579651: 0.0
2025-02-10T09:52:49.640605: 0.0
2025-02-10T09:52:52.732814: 0.0
2025-02-10T09:52:55.789193: 0.0
2025-02-10T09:52:58.867323: 0.0
2025-02-10T09:53:01.943444: 0.0
Sorted Values: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
Trimming highest and lowest: [0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0, 0.0]
Average: 0.0 => Rounded: 0.0
Final pm02Compensated value stored: 0.0
Data logged at 2025-02-10T09:54:05.109653
2025-02-10T09:53:28.103608: 0.0
2025-02-10T09:53:31.216438: 0.0
2025-02-10T09:53:34.296985: 0.0
2025-02-10T09:53:37.372369: 0.0
2025-02-10T09:53:40.539583: 0.0
2025-02-10T09:53:43.604735: 0.0
2025-02-10T09:53:46.698252: 0.0
2025-02-10T09:53:49.750345: 0.0
2025-02-10T09:53:52.832900: 0.0
2025-02-10T09:53:55.898171: 0.0
2025-02-10T09:53:58.965873: 0.0
2025-02-10T09:54:02.044585: 0.0
Data logged at 2025-02-10T09:55:05.014974
2025-02-10T09:54:28.103690: 0.0
2025-02-10T09:54:31.220519: 2.81
2025-02-10T09:54:34.295498: 2.9
2025-02-10T09:54:37.366560: 2.9
2025-02-10T09:54:40.438247: 2.9
2025-02-10T09:54:43.511212: 2.9
2025-02-10T09:54:46.606957: 2.9
2025-02-10T09:54:49.655432: 2.9
2025-02-10T09:54:52.746052: 2.99
2025-02-10T09:54:55.799464: 3.07
2025-02-10T09:54:58.870024: 3.07
2025-02-10T09:55:01.960419: 3.07
Sorted Values: [0.0, 2.81, 2.9, 2.9, 2.9, 2.9, 2.9, 2.9, 2.99, 3.07, 3.07, 3.07]
Trimming highest and lowest: [2.81, 2.9, 2.9, 2.9, 2.9, 2.9, 2.9, 2.99, 3.07, 3.07]
Average: 2.9339999999999997 => Rounded: 2.93
Final pm02Compensated value stored: 2.93
Data logged at 2025-02-10T09:56:05.225285
2025-02-10T09:55:28.103783: 0.0
2025-02-10T09:55:31.229108: 0.0
2025-02-10T09:55:34.301676: 0.0
2025-02-10T09:55:37.386761: 0.0
2025-02-10T09:55:40.444171: 2.81
2025-02-10T09:55:43.516230: 2.99
2025-02-10T09:55:46.620974: 2.99
2025-02-10T09:55:49.660691: 3.33
2025-02-10T09:55:52.835369: 3.42
2025-02-10T09:55:56.018025: 3.51
2025-02-10T09:55:59.089630: 3.42
2025-02-10T09:56:02.154025: 3.25
Sorted Values: [0.0, 0.0, 0.0, 0.0, 2.81, 2.99, 2.99, 3.25, 3.33, 3.42, 3.42, 3.51]
Trimming highest and lowest: [0.0, 0.0, 0.0, 2.81, 2.99, 2.99, 3.25, 3.33, 3.42, 3.42]
Average: 2.221 => Rounded: 2.22
Final pm02Compensated value stored: 2.22
