Help Us with the Wi-Fi Issue of Firmware 3.6.0
Hi @tadawson ,
Could you send the log to support and say forward it to me? https://www.airgradient.com/support
Thank you for your time helping.
Done!
Any insights why 3.6.0 and above won’t boot, when 3.4.1 will from the same repo?
3x I-9PSL (Kit) 1x O-1PST (Kit)
Regular Wifi disconnects since the 3.6.0 update. somtimes after ~30mins since last reboot, sometimes after 12h+. It seems to happen more frequent to my O-1PST (Kit) sensor compared to the indoor units - might be releated to my Wifi Mesh setup and that the chances are higher that the outdoor unit will use a repeater rather than the router itself.
the LED on the left is always red, the display shows the “Wifi” disconnected" symbol but the sensors values are constantly updated on the display. My sensors don’t recover from that state, only disconnecting the power helps.
Fritzbox 7590 AX as main router, 2x Fritzbox 1200 AX repeater connected via Ethernet to the router, 1x Fritzbox 1200 repeater operating as Wifi Bridge without Ethernet connection. All running in a Mesh setup with seperate SSIDs for 2.4GHz and 5.0GHz Wifi.
  • O-1PST (Kit)
   "country":"DE",
   "pmStandard":"ugm3",
   "ledBarMode":"co2",
   "abcDays":8,
   "tvocLearningOffset":12,
   "noxLearningOffset":12,
   "mqttBrokerUrl":"",
   "temperatureUnit":"c",
   "configurationControl":"local",
   "postDataToAirGradient":true,
   "ledBarBrightness":20,
   "displayBrightness":20,
   "offlineMode":false,
   "httpDomain":"",
   "disableCloudConnection":false,
   "monitorDisplayCompensatedValues":false,
   "model":"O-1PST",
   "corrections":{
      "pm02":{
         "correctionAlgorithm":"epa_2021",
         "slr":null
      "atmp":{
         "correctionAlgorithm":"ag_pms5003t_2024",
         "slr":null
      "rhum":{
         "slr":null
   "extendedPmMeasures":false
  • I-9PSL (Kit) #1
   "country":"DE",
   "ledBarMode":"co2",
   "abcDays":8,
   "mqttBrokerUrl":"",
   "httpDomain":"",
   "model":"I-9PSL-DE",
   "corrections":{
      "pm02":{
         "slr":null
  • I-9PSL (Kit) #2
   "country":"DE",
   "ledBarMode":"co2",
   "abcDays":8,
   "mqttBrokerUrl":"",
   "httpDomain":"",
   "corrections":{
      "pm02":{
         "slr":null
  • I-9PSL (Kit) #3
   "country":"DE",
   "ledBarMode":"co2",
   "abcDays":8,
   "mqttBrokerUrl":"",
   "httpDomain":"",
   "corrections":{
      "pm02":{
         "slr":null
I’m running a FritzBox Mesh with separated SSIDs for the 2.4GHz and 5GHz bands.
FritzBox Mesh setup: Fritzbox 7590 AX as main router, 2x Fritzbox 1200 AX repeater connected via Ethernet to the router, 1x Fritzbox 1200 repeater operating as Wifi Bridge without Ethernet connection.
I use static IPs assigned via the DHCP server of my FritzBox router for some WiFi network devices. I tried static and dynamic IP addresses for my Airgradient sensors and the disconnects do happen for both scenarios.
All of my four sensors are connected to the AirGradient dashboard, which regularly report them as offline via email.
All four sensors are connected to my HA instance. All are using a local configuration source as per default setting of the HA integration. I also tried to switch them to cloud configuration but this didn’t result in any changes regarding the WiFi disconnect issue.
Downgrading the firmware to 3.4.1 via the AirGradient Dashboard fixes the disconnect issues.
Also on a sidenote: I had a I-9PSL (Kit) sensor connected to my PC running the Online Debug Tool for about ~12h per day for three days total. While the Online Debug Tool was running no WiFi disconnects did occour - when my PC was in standby and did only deliver power via USB to the sensor the disconnects did happen again.
About a week ago, I was having persistent offline errors after I turned on my ASUS RT_AX86U wireless router’s WiFi Agile Multiband feature. More often on the outdoor, O-1PST, than the I-9PSL-DE. I attributed the difference with the sub-freezing temperatures in the Chicago region at the time. Both are firmware 3.6.0.
Neither has gone offline since I turned WiFi Agile Multiband off.
Hi everyone who has experienced the issue of the 3.6.0 @gis @tadawson @jmaguire @tom_shell @gianfranco.bottini @MarKusTech @pret79 @ynoterdep ,
We are testing FW 3.6.2 which potentially fixes the issue of 3.6.0.
We would appreciate it if you could help us test the 3.6.2 to see if the issue persists or is completely fixed.
If you are interested, please let us know your ‘Place ID’ via our support form: https://www.airgradient.com/support
Please also refer to this reply in your support ticket.
How to see your Place ID?: Go to your AirGradient Dashboard > General Settings > Place [as shown in the below image]
We will enable the 3.6.2 on your AirGradient Dashboard, so you can select and update your monitors to 3.6.2.
For those who don’t use the AirGradient Dashboard, please feel free to contact us via the support form mentioned above and request the firmware file so you can flash it to your monitors.
Thank you!
Sent, and I am also working with Samuel with another test build. Forgot to mention this discussion though. It entered as ticket 27890.
Thank you, @tadawson. I really appreciate your help.
Please don’t worry about mentioning this discussion.
I am currently conducting a preliminary test of the basic functionalities of the FW 3.6.2 to make sure it works properly and does not pose any other new issues. Then we will roll out 3.6.2 to you (and those who would like to test this with us).
Thank you.
NP! In the meantime, I’m going to get the test branch build Samuel sent me loaded in the morning as well.
Sent, I downgraded to FW 3.4.1 and had no issues since then, I’ll be glad to test FW 3.6.2
Thank you
FYI, the test build sent to me by Samuel (which appears identical to that discussed here) does appear to resolve the problem. I went red on AP drop, but recovered WiFi to purple state for about 60 seconds, and then back up and online.
Logging did show recovery attempts, unlike the logging fr0m 3.6.0.
The logs were sent in on 27865 to Samuel if anyone else wants to find them.
It shows at Version 3.6.1-1 at boot, but oddly does not display a version via the dashboard.
I’m going to let this run for a bit and see what transpires.
The issue has been already described multiple times and I see that a fix is on the way. I have an indoor and an outdoor, O-1PST and I-9PSL, both on firmware 3.6.0. They are both affected, too. Maybe the only new informationt to add here is that my two monitors disconnect perfectly simultanous from wifi (synchronized to the second) at random intervals without obvious root cause. I usually power cycle them to re-connect.
Currently they are back at work. I will provide more details in the questionaire below.
  1. Model number of the monitor that has the issue? (I-9PSL-DE, O-1PST, etc.)
  2. Please describe the symptom of the issue you experienced. For example, it randomly disconnects from your Wi-Fi, or you can observe some patterns in its behavior.
    both monitors, i-9PSL and O1-PST disconnect randomly (every 1-3 days), but simultanously (exactly to the second)
  3. What does the OLED screen of the monitor show when it is disconnected? And what is the color of the LED on the left of the monitor (red, purple, etc.)?
    currently they work - no means to observe
  4. Network setup: Describe your network setup. Please also specify the brand and model of each network equipment.
    AVM Fritz!box 5590 fiber, repeater 1750E and repeater 1200
  5. AirGradient monitor configuration - accessible via web browser with a phone or computer connected to the same Wi-Fi as the monitor that has the issue using: {“country”:“TH”,“pmStandard”:“ugm3”,“ledBarMode”:“pm”,“abcDays”:30,“tvocLearningOffset”:60,“noxLearningOffset”:60,“mqttBrokerUrl”:"",“temperatureUnit”:“c”,“configurationControl”:“local”,“postDataToAirGradient”:true,“ledBarBrightness”:100,“displayBrightness”:100,“offlineMode”:false,“monitorDisplayCompensatedValues”:false,“model”:“O-1PST”,“httpDomain”:"",“disableCloudConnection”:false,“extendedPmMeasures”:false}
{“country”:“DE”,“pmStandard”:“ugm3”,“ledBarMode”:“co2”,“abcDays”:8,“tvocLearningOffset”:12,“noxLearningOffset”:60,“mqttBrokerUrl”:"",“httpDomain”:"",“temperatureUnit”:“c”,“disableCloudConnection”:false,“configurationControl”:“local”,“postDataToAirGradient”:true,“ledBarBrightness”:0,“displayBrightness”:0,“offlineMode”:false,“monitorDisplayCompensatedValues”:false,“model”:“I-9PSL-DE”,“corrections”:{“pm02”:{“correctionAlgorithm”:“custom”,“slr”:{“intercept”:-0.319,“scalingFactor”:0.015,“useEpa2021”:false}},“atmp”:{“correctionAlgorithm”:“none”,“slr”:null},“rhum”:{“correctionAlgorithm”:“none”,“slr”:null}},“extendedPmMeasures”:false}
  1. Is your Wi-Fi network using a unified band (a combined Wi-Fi name without separating 5GHz and 2.4GHz)?
    Yes
  2. Is your Wi-Fi a mesh system, have multiple access points, or use Wi-Fi extender?
    Yes
  3. Do you have your Wi-Fi DHCP server configured to assign a static IP address for connected devices?
    No
  4. Does the monitor connect to the AirGradient dashboard?
    Yes
  5. Does the monitor connect to Home Assistant or other platforms?
    Yes
  6. Is this Wi-Fi issue gone after you downgrade your AirGradient monitor from firmware 3.6.0 to 3.4.1?
    Didn’t try.
Hey guys! I have allowed the place IDs that you sent us via the AirGradient support to automatically update your AirGradient ONE/Open Air to FW 3.6.2.
You don’t have to do anything else when it’s time for the monitor to perform an OTA FW check (typically every 1 hour), your monitors will automatically download and install the 3.6.2. In case you don’t want to wait, you can power cycle (unplug and plug in again) your AirGradient monitors so they will check the new firmware when they boot up and perform the update.
Hi @rural_breeze , would you be interested to test the FW 3.6.2 which could fix the issue?
Please let us know your Place ID via support channel as I mentioned in a reply above: Help Us with the Wi-Fi Issue of Firmware 3.6.0 - #26 by Tai_AirGradient
And everyone interested in testing, please also feel free to let us know your place ID via support.
We decided to not roll out the 3.6.2 globally at the moment, as we want to make sure it fixes the existing Wi-Fi issue of the 3.6.0.
Once we are sure about it, we will make a global rollout as soon as possible.
I appreciate everyone for your kind help.
Thank you!
Hi @tadawson , thank you a lot again for the test.
I believe the .bin file that @Samuel_AirGradient gave you is an untagged firmware version for testing the patch, so it will show something like 3.6.1-1, and the dashboard won’t display the version (which is expected).
Since this firmware is untagged, the dashboard will not be able to manipulate (automatically force) the OTA FW update over that monitor running this untagged firmware.
If you would like to get back to a normal firmware (with auto OTA update), you can reflash the monitor with 3.4.1 in AirGradient ONE (I-9PSL), Open Air (O-1PST) and Open Air Max (O-M-1PPST...) Firmware Versions
Then it will later automatically update to 3.6.2.
Please feel free to let me know if you encounter any issues.
Thanks. I’ll keep this on until I see 3.6.2 drop to ensure no other issues. I had just noted those differences, well, because noting things is part of testing. :slight_smile:
Hi @Tai_AirGradient , would you check if support added my PlaceID, because I can’t update to FW 3.6.2 yet.
Thank you
Hi @gianfranco.bottini I have set the target firmware for your dashboard to 3.6.2 already. I believe it could take a while (a few hours) before your air monitors detect the new firmware, as the AirGradient ONE and Open Air checks for a new update once every hour.
Anyway, you can simply force it to update more quickly by power cycling the monitor (unplugging and plugging in the power adapter or the USB-C), as the AirGradient ONE and Open Air will also check for a new update every time it first boots up (after it loses power and has access to power again).
Please note that from your dashboard view, you may not see a selected firmware as 3.6.2 in the firmware setting page; you might see a blank ‘selected’ version, which you can ignore.
It could look like this:
Please completely ignore this and don’t have to do anything to get the 3.6.2. Then, you can open the ‘Show Monitor Information’ of each monitor to see if it is updated or not.
Thank you, and please feel free to let me know if that doesn’t work.
For what it’s worth, my outdoor (was on 3.4.1, not Samuel’s build) has picked up 3.6.2 . . .
The firmware setting page was showing “Seleceted”, as in the screenshot posted by Tai and the firmware updated to the 3.6.2 for both my monitors :slight_smile:
@Tai_AirGradient : I sent you my place ID via the zendesk support. Feel free to update my devices. I will see it in the HA integration when it happened and will come back to you in case of further disconnects or other unexpected effects. Cheers
