I am trying to calibrate PM2.5 on a AG1 indoor device. When I click on advanced settings beside the device name in the dashboard, it opens a window with a description of the PM2.5 calibration. But the area on the bottom where the PM2.5 correction formula dropdown should appear is missing. (only the down arrow is visible). I’m stuck!
How do I get this dropdown to function properly, so I can select the proper serial number?
hi @Chris_Pollock! This is a known issue with the latest dashboard release and has already been escalated to the dashboard dev team by @Tai_AirGradient. Apologies for the inconvenience - a fix should be on the way soon!
Thanks!
What’s the timeline for the fix?
Our developer has fixed it! Could you please check and let us know if there’s still an issue? Please note to click the dashboard update prompt first.
Thank you!
