I’ve attempted to upload both the PRO and Outdoor versions with Blink following the documentation on the website. I’ve attempted this with Arduino IDE on both Mac and Windows. I’ve used the USB cables that are included with the Airgradient kit and my own cables. Uploading always fails with the same issue. Here’s a paste from my latest attempt on Windows:
. Variables and constants in RAM (global, static), used 28104 / 80192 bytes (35%)
║   SEGMENT  BYTES    DESCRIPTION
╠══ DATA     1496     initialized variables
╠══ RODATA   920      constants
╚══ BSS      25688    zeroed variables
. Instruction RAM (IRAM_ATTR, ICACHE_RAM_ATTR), used 59667 / 65536 bytes (91%)
╠══ ICACHE   32768    reserved space for flash instruction cache
╚══ IRAM     26899    code in IRAM
. Code in flash (default, ICACHE_FLASH_ATTR), used 232148 / 1048576 bytes (22%)
╚══ IROM     232148   code in flash
esptool.py v3.0
Serial port COM3
Connecting........_____....._____....._____....._____....._____....._____....._____
A fatal esptool.py error occurred: Failed to connect to ESP8266: Timed out waiting for packet header
I must be doing something obvious wrong here.
I’ve tried holding down the button on the device and uploading. I get the same result.
In my port list on Windows I see COM3 (ESP32S3 Dev Module) and use it to upload.
I’m using LOLIN(WEMOS) D1 R2 & Mini as the selected board.
