Please take a look. I’ve been trying to connect airgradient one to new router for hours now with no result. I’ve separated the SSIDs and I am 100% certain that the SSID and password are correct. I’ve had the monitor on an older firmware so I flashed it to 3.3.8 and messages on the manitor changed to “connecting to wifi” but with same result. Here is a log
ESP-ROM:esp32c3-api1-20210207
Build:Feb 7 2021
rst:0x15 (USB_UART_CHIP_RESET),boot:0xc (SPI_FAST_FLASH_BOOT)
Saved PC:0x4208083e
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd5810,len:0x438
load:0x403cc710,len:0x918
load:0x403ce710,len:0x25f4
entry 0x403cc710
Serial nr: 404cca684770
Reset reason: ESP_RST_UNKNOWN
[Configure] Info: Reading file…
[Configure] Info: Reading file: success
[Configure] Info: Parse file to JSON
[Configure] Info: corrections not found
[Configure] Info: {“country”:“TH”,“pmStandard”:“ugm3”,“ledBarMode”:“co2”,“abcDays”:8,“tvocLearningOffset”:12,“noxLearningOffset”:12,“mqttBrokerUrl”:"",“httpDomain”:"",“temperatureUnit”:“c”,“disableCloudConnection”:false,“configurationControl”:“both”,“postDataToAirGradient”:true,“ledBarBrightness”:100,“displayBrightness”:100,“offlineMode”:false,“monitorDisplayCompensatedValues”:false}
Detected ONE_INDOOR
[OledDisplay] Info: begin
Firmware Version: 3.3.8
LED bar brightness: 100
Init SGP41 success
initializing PM sensor
cleared 0 byte(s)
setting active mode
7 byte(s) written
Set S8 AbcDays successful
[AGSERIAL] Info: IICSerial initialized
[AGSERIAL] Warning: IICSerial failed open serial line, retry…
[AGSERIAL] Error: IICSerial failed open serial line, give up…
Cellular module not available, using wifi
*wm:AutoConnect
*wm:Connecting to SAVED AP: Obada Wii-Fi2
*wm:AutoConnect: FAILED for 502 ms
*wm:StartAP with SSID: airgradient-404cca684770
*wm:AP IP address: 192.168.4.1
*wm:Starting Web Portal
[WifiConnector] Info: Wait for configure portal
[ 30241][E][WebServer.cpp:638] _handleRequest(): request handler not found
[ 30779][E][WebServer.cpp:638] _handleRequest(): request handler not found
[ 30914][E][WebServer.cpp:638] _handleRequest(): request handler not found
*wm:17 networks found
[ 32357][E][WebServer.cpp:638] _handleRequest(): request handler not found
[ 43299][E][WebServer.cpp:638] _handleRequest(): request handler not found
[ 43778][E][WebServer.cpp:638] _handleRequest(): request handler not found
[ 43933][E][WebServer.cpp:638] _handleRequest(): request handler not found
[ 48263][E][WebServer.cpp:638] _handleRequest(): request handler not found
*wm:Connecting to NEW AP: Obada Wii-Fi2
*wm:[ERROR] Connect to new AP Failed
[ 67603][E][WebServer.cpp:638] _handleRequest(): request handler not found
*wm:config portal has timed out
Failed connect to WiFi
Build:Feb 7 2021
rst:0x3 (RTC_SW_SYS_RST),boot:0xc (SPI_FAST_FLASH_BOOT)
Saved PC:0x40382504
SPIWP:0xee
entry 0x403cc710
Reset reason: ESP_RST_SW
Detected ONE_INDOOR
Init SGP41 success
cleared 0 byte(s)
setting active mode
7 byte(s) written
*wm:AutoConnect
*wm:AutoConnect: FAILED for 503 ms
[186253][E][WebServer.cpp:638] _handleRequest(): request handler not found
I couldn’t figure anything useful from it. Does this show something useful to any of you? Thanks
