SGP41 not found after a power cycle
After power cycling my AirGradient ONE, I am no longer getting and PM, NOx, and VOC measurements. CO2, humidity, and temperature are fine. I saw a brief message on the screen as it booted up saying that the SGP41 was not found.
I’ve power cycled it several times, and I get the same results. I’m on the 3.6.0 firmware.
Any ideas, or did the sensor go bad?
Hi @Don_Allingham! Can you please take a log here: Online Debug and send it in via our support form? https://www.airgradient.com/support/
I left it unplugged for a couple of hours and plugged it back in, and the error went away. I’ll keep monitoring this, and if it repeats again, I’ll send in the logs.
Having the same issue after upgrading from 3.4.1 to 3.6.2
[ 7194][E][Wire.cpp:513] requestFrom(): i2cRead returned Error -1
Init SGP41 failure
Hi there!
This will help see the issue in detail. Also please mention whether this was an assembled unit or a DIY kit when you submit the ticket. Thanks!
