I intend to get the Pro Kit and install a TVOC sensor. Since SGP30 is being discontinued, has anyone had experience using SGP40 (with a board with the same pinout; VIN, GND, SCL, SDA ) as a drop-in replacement?
Seems like the main difference is that SGP40 reports a VOC Index rather than Total VOC in ppb, as well as a much faster switch-on time of 1h: https://sensirion.com/media/documents/B2035E62/617BDA44/Sensirion_Gas_Sensors_SGP30_SGP40_transition_guide.pdf
Also, has anyone had experience using SGP41 which also measures NOx?
