Hi @Tai_AirGradient , thanks for your answer.
I’ve been thinking about this for some time and want to share my thoughts in detail so you can understand my thinking process.
Request for finer granularity at low levels
On the AirGradient ONE I have been using the CO2 level LED mode until I switched to the GO IAQS mode when it became available. At home I have an air purifier and the PM2.5 is so low that the GO IAQS score only decreases because of my CO2 level. I I must say that I really like the increased granularity in the range of 0-800ppm.
Here’s the difference:
CO2 LED mode
0-600 = Green
600-800 = 2x Green
800-1000 = 3x Yellow
GO IAQS LED mode
0-500 = 1x Blue
500-700 = 2x Blue
700-800 = 3x Blue
800-900 = 4x Orange
I always try to stay under 800ppm, so when I see that the level is above 800 my action is always the same: increase ventilation. So granularity above 800 is not so important to me, it can be more coarse. Most of the time I am in the 400-800 range and I enjoy the increased granularity because I can see at a glance what the level is and also how quickly it rises when I am entering and sitting in a room. This way I can already predict when it will rise above 800 and ventilate before it rises above 800.
So at the current AirGradient ONE CO2 LED mode I find the granularity under 800 too coarse.
AirGradient Go LEDs
What colors does the Go have? I think the only way to see all the colors is by playing the tetris melody? When I play the tetris melody I think I can see the following colors:
Red
Orange
Yellow
Green
Blue
Purple
I find the yellow, orange and green a bit similar in color. I can see the difference between them, but it might be confusing to the average consumer. The green is more of a green-yellow and especially orange and yellow are quite close. The LED colors of the AirGradient One are all more distinguishable to me by the way. So I’m not sure it would be a good idea to use yellow, orange and green together on a score LED system on the Go.
The Go also has white touch LEDs in addition to the color LEDs. So I thought why not also use these for the quality score. I find them rather useless as touch LEDs to be honest. At the current firmware they can be enabled and turn on when I press a button. This just blinds me and I can see on the screen anyway if my press is registered. The only way I can see them useful as touch LEDs would be to change settings in the dark. But the behaviour would need to be different: The screen and the 3 buttons would have to light up and kept lit up for say 10 seconds after a button press. But since there’s no screen LEDs on my Go it doesn’t make sense to lit up the buttons since I still need to shine a light on the screen anyway to be able to read it. Maybe an idea for a version 2 of the Go in the future to have a lit screen. I read in a different forum post on this forum that the screen LEDs have been cancelled last moment because they didn’t really work? It seems there’s a space and connection for a LED left and right of the screen, but there are no LEDs there on my device.
I also see two front LEDs top left and top right, what are these for? As far as I can tell they have no functionality on the current firmware.
My suggestion
The AirGradient ONE in GO IAQS LED Mode behaves as follows when the PM2.5 is below 3 µg/m³ :
0-500 ppm = 1x Blue
500-700 ppm = 2x Blue
700-800 ppm = 3x Blue
800-900 ppm = 4x Orange
900-1100 ppm = 5x Orange
1100-1300 ppm = 6x Orange
1300-1400 ppm = 7x Orange
1400-2000 ppm = 8x Red
2000-3200 ppm = 9x Red
3200-4400 ppm = 10x Red
4400 ppm and above = 11x Red
I would like to suggest the following 9-step scale and LEDs for the AirGradient Go CO2 / PM2.5 / GO IAQS LED modes:
0-500 ppm / 0-3 µg/m³ / Score 10 = Blue + 1x White touch LED
500-700 ppm / 3-8 µg/m³ / Score 9 = Blue + 2x White touch LED
700-800 ppm / 8-11 µg/m³ / Score 8 = Blue + 3x White touch LED
800-900 ppm / 11-13 µg/m³ / Score 7 = Orange + 1x White touch LED
900-1100 ppm / 13-19 µg/m³ / Score 6 = Orange + 2x White touch LED
1100-1300 ppm / 19-23 µg/m³ / Score 5 = Orange + 3x White touch LED
1300-1400 ppm / 23-26 µg/m³ / Score 4 = Orange + 3x White touch LED
1400-2000 ppm / 26-39 µg/m³ / Score 3 = Red + 1x White touch LED
2000-3200 ppm / 39-64 µg/m³ / Score 2 = Red + 2x White touch LED
3200-4400 ppm / 64-88 µg/m³ / Score 1 = Red + 3x White touch LED
4400 ppm and above / 88 µg/m³ and above / Score 0 = Red + 3x White touch LED
This way the colors are easy to understand by the average consumer. And there’s still granularity by using the white touch LEDs. The addition of the white touch LEDs could be an optional setting for users that want to see granularity (like me).
What do you think about my suggestion?
