Low Readings from Plantower PMS5003
Here it is:
“country”: “US”,
“pmStandard”: “ugm3”,
“ledBarMode”: “pm”,
“abcDays”: 0,
“tvocLearningOffset”: 360,
“noxLearningOffset”: 360,
“mqttBrokerUrl”: “”,
“temperatureUnit”: “f”,
“configurationControl”: “local”,
“postDataToAirGradient”: true,
“ledBarBrightness”: 2,
“displayBrightness”: 1,
“offlineMode”: false,
“monitorDisplayCompensatedValues”: false,
“model”: “O-1PST”,
“corrections”: {
“pm02”: {
“correctionAlgorithm”: “epa_2021”,
“slr”: null
Looks correction haven’t been applied locally. There are two ways to do this:
  1. Set configuration source for the monitor on home assistant to cloud for a moment until the monitor receive the correction configuration, and you can set it back to local
  2. Or, you can set it manually by using http client tools (eg. cURL) and follow this steps: arduino/docs/local-server.md at master · airgradienthq/arduino · GitHub
Unfortunately neither of these methods worked.
Method 1: I set the configuration source in HA to “Cloud” and waited for hours, restarted everything. Nothing changed.
Method 2: I ran the following command according to the github page:
curl --location -X PUT “http://airgradient_.local/config” --header “Content-Type: application/json” --data “{“corrections”:{“pm02”:{“correctionAlgorithm”:“slr_PMS5003_20240417”,“slr”:{“intercept”:0,“scalingFactor”:0.02799,“useEpa2021”:true}}}}”
The windows CMD says “Success”, but the content of http://airgradient_.local/config remains unchanged. Does this correction not work with PMS5003_20240417?
BTW, my indoor monitor was able to apply the correction locally in HA without me doing any extra setting.
Hi @Bunbury ,
Could you send a support ticket regarding this here and say the ticket is for me (samuel) while provide your serial number. Thanks.
I believe there is a typo in the article. It says “We will not apply the formula at values < 30ug/m3”, however I think it should be “We will not apply the formula at values > 30ug/m3”. The formulas are meant to correct the low PM readings.
