>>> Join Us in the Fight Against Air Pollution
Location of firmware Source Code for AirGradient DIY PRO pre-soldered kit
I have an AirGradient DIY PRO pre-soldered kit. Although I located the webpage where one can directly flash the unit, I cannot find the actual firmware source code.
The GitHub repository seems to only have code for the PRO version and its display is oriented differently.
Thanks,
See here: Library code for DIY Pro not working correctly with the display - #4 by marmoset
But basically just change the _R3 to _R2 to fix the orientation.
