My very pleasure!
And if you guys don’t mind, please feel free to provide a little more information about the issue here: Help Us with the Wi-Fi Issue of Firmware 3.6.0
I’ll make sure that it is our priority to fix this issue.
Thank you!
My very pleasure!
Thank you!
just went offline since 24 Jan 15:00 CET
Curious fact it happened on both my Monitors (Outdoor and Indoor) at the same time.
I thought it was something about the 5Ghz and Band steering, it seems not.
Next step: I’ll give a try with an older version of the FW.
Thanks @Tai_AirGradient for your efforts!!
How do you stop it upgrading itself again?
Hi @drowsy , please make sure you
Please let me know if it still forces itself to update to 3.6.0.
As per earlier comment - it’s not connected to the cloud. It’s only used with Home Assistant.
They have updated the Firmware page finally, and now you can install 3.4.1 from this link:
You will have to reconfigure your Wifi configuration, and if you made any settings changes through HA you may need to set them again.
@drowsy you can flash the firmware as @MallocArray suggested above. And in the initial Wi-Fi setup. You can check the ‘Prevent Cloud to AirGradient Server’ box. It should not upgrade itself now.
Set a static DHCP allocation and blocked it at my router. Sorted
