Indoor AirGradient Fan Noise Increased after a year of ownership
I have had three I-9PSL in my house for about a year now. I noticed last night the one in my room suddenly had audible fan noise. This high pitch hum is audible from about 8 feet away.
Checking my other units of they seems to have no audible noise, at this distance. I attempted to blow out the unit with compressed air to no effect.
I found this old post describing a fix someone found for this issue. I am going to attempt this fix today.
Just wanted to make folks aware this is still a potential issue that occurs with these units. Will update with my results later.
Hi @secretformula, welcome to our community!
Thank you for sharing your concern.
In the meantime, would you mind recording some videos that include the audible noise coming from the monitor and sending them to us via https://www.airgradient.com/support ?
Thank you!
@secretformula I’ve also noticed a similar thing, after a similar time. I’m guessing it’s the PM sensor.
Hi @Smithandjosh, may I also ask you to send a video of it with an audible noise to our support? The PMS sensor should typically last a few years. Our support team is happy to investigate and help you with the issue. Thank you!
I am also here because of the noise. It started a few weeks ago. My indoor Airgradient One is not even a year old. I’ve opened the cover and found that the fan holes are full of dust. Tried to clean it, but the holes are just too small, so I stopped. I don’t want to damage anything inside. The sensor is working, but during night hours when I try to fall asleep, the sound bothers me too much, so I had to banish it from my room. I there any maintenance to do on the hardware? Except wipe the outside with a soft cloth.
Hi @Gellert_Horvath, could you please contact us via https://www.airgradient.com/support ? We are happy to help. Thank you!
I had to temporarily unplug and replug the AG One in my bedroom (alien display - trying a different power source). As I went to unplug it, I noticed a faint whine coming from the One that also came back after I plugged it in again. The One is situated on a shelf about 3 foot from the foot of my bed, so it’s too far away for me to hear it at night.
I got the One in February 2025, so it’s been running for a long time. I suspect it’s been sucking up dust, as the shelf can get dusty. When I get time, I’ll take it apart and check inside and give it a good clean out.
There’s no problem with another One that I bought about the same time and has been running ever since, but I think that its location, in the living room is more dust free.
Hi @Rog, thank you for sharing your experience.
Regarding the alien display, there could be a potential interference source nearby. If possible, try relocating the air monitor and observe whether you still see the issue.
Please feel free to reach out to us via https://www.airgradient.com/support if you have any questions. Thanks!
The alien display is something that happens infrequently on the bedroom and another AG, but not something I’m bothered about because I rarely read from the AG screen as the AG is used as a data source for Home Assistant. You are probably right about interference being the cause. I changed the power source out of curiosity to see if it made a difference.
Hi @Rog, it seems to be caused by an interference source close to the monitor, according to our engineer’s discussion with the display supplier. Please feel free to update if you still occasionally see the issue after relocating or changing the power adapter. Thanks!
Hi @elizabethrobinson, welcome to our community and thank you for your feedback!
I opened up my AG One the other day to check inside.
There was a bit of dust build up on the Plantower fan vent, as expected, but not enough to really inpede the air flow. The rest of the inside of the One was spotless.
The fan sucks air in through the small holes in the Plantower case, past the laser beam and blows it out to inside the One. The fan is directly behind the vent. Therefore, it’s possible that there may be some dust build up inside the case and on the other side of the fan. Blowing on the vent will remove dust from the vent area and will probably remove it from the other side of the fan as well.
I cleaned the vent by blowing the dust away. I then finished this off with a battery air duster on its lowest setting. This was a gentle blow and it left the vent spotless (see before and after).
The Plantower is a sealed unit and cannot be easily taken apart for internal access. I realised afterwards that perhaps I should have tried picking some of the dust away with a toothpick first, as blowing on the dust probably pushed some of it to inside the Plantower. However, that is likely to have made little difference as most of the dust blew out as a cloud.
Regarding the fan noise I mentioned in my earlier post.
On closer examination, with the One powered up, the whine sound is very quiet and only noticeable by putting an ear to the top of the One case vent. I suspect that this may have been like it from new and not a result, in my case, of any dust build up. The sound still remained after the Plantower clean. It isn’t distracting and I never notice it. This is probably different to what other people have mentioned where it appears that they have a louder sound from the One which has increased over time.
@Rog, thank you so much for sharing. As you said, the PM2.5 module’s fan noise should not be too loud, even after being used for a while. However, if you encounter abnormally loud noise from the fan, please feel free to let us know.
