Help Us with the Wi-Fi Issue of Firmware 3.6.0
Hi @Shinji, would you mind trying to clean-flash a firmware to your monitor?
Connect your monitor to your PC via a USB cable, and go to AirGradient ONE (I-9PSL), Open Air (O-1PST) and Open Air Max (O-M-1PPST...) Firmware Versions
Follow the instructions there, and when this window is prompted, please check ‘Erase device’. Please note that this will erase your previous configurations, you’ll have to connect it to your Wi-Fi again after this (as if you have just received a new monitor).
After the flashing is finished, please try connecting your monitor to your AP.
Note that if you had selected your target firmware on the AirGradient Dashboard to 3.4.1, on the first boot after firmware flash (the firmware here is 3.6.2), the monitor might not be responsive for a while, as it will try to communicate with the server and downgrade itself to 3.4.1. It will take a while.
Hello @Tai_AirGradient, I apologise for the delay. I tried the erase procedure for my initial report, but I have done it again just in case it behaves differently coming from 3.4.1.
Unfortunately, the symptoms are the same. It fails to connect to my home network but can connect to my phone.
Hi @Shinji, thank you for your reply!
Given that the AirGradient monitor can connect to your phone’s hotspot, it sounds like there’s something to do with your Wi-Fi access point. Could you please provide the information regarding these so we can investigate further?:
- Network setup: Describe your network setup. Please also specify the brand and model of each network equipment.
- Is your Wi-Fi a mesh system, have multiple access points, or use Wi-Fi extender?
- Do you have your Wi-Fi DHCP server configured to assign a static IP address for connected devices?
- Could you please provide a screen recording or screenshots when you are trying to connect the AirGradient monitor to Wi-Fi and get the error message?
Thanks a lot in advance!
Hello @Tai_AirGradient, I’ve done some troubleshooting with my WiFi configuration. I use Unifi for my access points (only). I finally got it connected to my network.
I have a theory now since after reconnecting, I was reminded that I “locked” the device to a particular AP. I think that because of how the locking is implemented, the monitor cannot initially connect to the SSID unless the AP it’s locked to is the only AP broadcasting the SSID. This holds true even if the monitor is right next to that AP. After it’s configured and connected once, the monitor has no problem with the lock, and is able to reconnect even after a power cycle.
I probably didn’t encounter this issue before since I configured the AP lock after initial setup of the monitor, and perhaps the firmware update in February essentially caused the monitor to go through some part of initial WiFi configuration again that doesn’t work with the lock.
I’m happy to provide more details in the support ticket, or do more specific troubleshooting to help support my environment, but I’m also happy to consider this as an unsupported WiFi configuration. In any case, thank you for your assistance in troubleshooting this!
Hello @Shinji, that’s impressive! Thank you for providing your findings.
Of course, we will greatly appreciate it if you could please provide more details about this, so we can document it and help people who will be experiencing an issue like this in the future.
If you don’t mind (I’m not sure if I’m asking too much), could you please create a forum post (topic) in the forum (Support category) discussing your issue and how you troubleshooted it? With a public post like this, it will not just help us improve our support experience, but will also be very helpful for the whole community who is experiencing issue like this (and maybe they’ll have something else to share and discuss).
However, if you are not comfortable that way, you can create a support ticket attached a link to this thread and provide more details about your issue and troubleshooting (including the details of a specific model of your AP and how to configure the setting would be great).
I appreciate it a lot. Thank you @Shinji !
Has there been any progress with this? I’m still seeing both of my devices losing wifi once or twice a week, and never at the same time. It’s getting annoying, I had to add a remote power device on the outdoor one as it isn’t easy to get to where it is plugged in order to reset it.
Hi @sjthespian thank you for your following up, and I am genuinely sorry that I didn’t give you an update. We have a few revisions of the firmware after v3.6.2 (but we haven’t released it globally to all users). Could you please contact us via our support page https://www.airgradient.com/support/ and let us know your Place ID of the AirGradient Dashboard? We can provide you with different firmware versions so you can try and see if the issue is gone after changing the firmware.
For your case, the white LED could indicate that it fails to post the data to our server. Could you please check on your Home Assistant (or other local-network platforms) if it also stops getting the data from the AirGradient monitors?
The ideal way is to collect the log via Online Debug | AirGradient Knowledge Base to diagnose the issue, but I understand that it could be a bit tricky if the issue occurs randomly (which means the monitor has to connect its USB to the logger (a PC) for the whole time). So my suggestion for a quick troubleshooting we can try is to perform a clean reflash of the firmware (checking the ‘Erase device’ box during the process). Please refer to: AirGradient Monitor Firmware Updates | AirGradient Knowledge Base
Additionally, since you have Wi-Fi and Zigbee coexisting. It’s also worth checking if your 2.4GHz Wi-Fi channel overlaps with the Zigbee radio.
I couldn’t get mine to connect to the AP no matter what, even after erasing and trying again, even whith the device right next to the AP. SSH-ing into the AP no hostpad events were being logged, but they were when I tried connecting with my phone, so AP seemed to be working fine.
Finally it did connect after I switched the 2.4 GHz channel from 13 to 3 on the AP -_-.
That’s interesting, @Guiorgy - thanks for the feedback. It might be a good idea to test different WiFi channels too @Tai_AirGradient - what do you think?
I remember someone else having trouble with channel 13 in the past.
Doing some quick research it looks like channel 13 isn’t commonly used in the US and ESP32 chips are supposed to do only passive scans of channels 12 and 13.
I’m not sure if the AirGradient code is setting a country at all or if by not defining one it is defaulting to the safest and not including 12 and 13.
For what is worth, searching the GitHub issues and this forum didn’t lead to a solution. Instead it was a clanker (LLM) that suggested that IoT devices struggle with channels above 11. Interestingly, this AP was set to use channel 13 for ages, the Airgradient must have been barely connecting to the further AP that was set to channel 1 isntead, and for some reason on the new firmware it wasn’t quite reaching it? (Edit: though, more likely, channel 1 saw increased usage in my surroundings (I’ve noticed an increase in SSIDs) and has nothing to do with the firmware, I think I had a drop or two in the past on the older firmware and only on this Airgradient, now I know why XD)
Either way, an option to set the country code during setup would be a welcome change, assuming that helps resolve such issues for those outside the US (like me).
I also remember seeing somehow that IoT devices struggle with channels 12, 13, and 14. We’ll test this out. Perhaps the first step would be to add this to the WiFi connectivity troubleshoot here: Troubleshooting WiFi Connectivity Issues | AirGradient Knowledge Base
Some months later, after firmware 3.60 caused Wi-Fi trouble and I set back all my monitors to 3.41 - is 3.41 still more stable concerning Wi-Fi connection in comparison to the current version 3.70?
Hi @lqms, I believe the current version (3.7.0) is quite stable after extensive tests we conducted. There is also a significantly lower number of Wi-Fi-related issue reports in 3.7.0 compared to 3.6.0.
In comparison with 3.4.1, there are a lot of improvements made along the way to 3.7.0, not only in Wi-Fi but also in server communication.
Thank you Tai, but in the end it sounds like 3.41 is still most stable concerning Wi-Fi connection?
Hi @lqms, hope you are doing well.
To give you an accurate answer, I briefly discussed this with Sam, our firmware engineer. He informed me that there were not a lot of changes concerning Wi-Fi between 3.4.1 and 3.7.0. We can say that they are pretty much the same. So we would recommend using the latest version (3.7.0).
Feel free to let me know if you have any other questions. Thanks!
Thank you, but from 3.41 to 3.60 there were changes which caused the Wi-Fi trouble. These changes have completely been taken back and 3.70 is more like 3.41 than like 3.60, or how can this be understood?
I’m asking in detail because I operate around 10 AirGradient Open Air at different places, and if there are Wi-Fi connection fails like with 3.60, I have to visit and restart all devices which causes a lot of work.
Hi @lqms, firmware version 3.7.0 is technically not a complete rollback to 3.4.1, it retains some properties that were first introduced in 3.6.0. For example, in 3.6.0, we introduced BLE Wi-Fi provisioning, and this is still present in later versions (3.6.x to 3.7.0).
However, the Wi-Fi bug that was introduced in 3.6.0 was already addressed in version 3.6.2, and this fix is also present in 3.7.0.
Your concern is valid, since a large deployment across different sites is a real pain if something goes wrong. I would suggest that you might want to stay on 3.4.1 as long as you find it works reliably to avoid the risk. It is quite difficult to say that one firmware is legitimately more stable than another in all conditions. Especially when users have a different environment, networking equipment, etc., which could cause issues that other users or we never experience.
However, if you would like to use some new functionalities and get improvements that made after 3.4.1, you might consider updating a few monitors before updating your whole fleet. Anyway, unfortunately, our current AirGradient Dashboard doesn’t have an option to set a target firmware for an individual monitor. So in case all of your monitors are in the same Place, you will have to create a new Place and temporarily migrate a monitor or two (that you would like to test running 3.7.0 on your specific network environment), keep them running for a while to see if they run reliably, then migrate them back to the old Place.
You can take a look at the firmware repository to see what was changed here: Releases · Open-Air-Foundation/firmware-one-openair · GitHub
