I have Go monitor s/n 10bda3e4a234 that’s currently running fw 1.1.2. Since receiving it a couple of months ago the temperature has read 4.1C too high and the humidity 15% too low. I was hoping that newer firmware releases would address this but now I’m not so sure. I’ve tried every calibration method I’m aware of, including those in the Windows Chrome app and those in the Android app, all to no avail. The Android app seems to allow me to set custom calibration methods for temperature and humidity, and while they seem to take, I’ve yet to see any change in the Go’s LCD readout, the Android app’s figures, or the Chrome app’s figures or charts.
Hi @aqiguy, I hope you are doing well.
Currently, the temperature and humidity calibration has not been implemented in the configuration of the AirGradient Go (any changes made to the temperature & humidity calibration on the mobile app and Dashboard won’t take effect on the Go). PM2.5 is the only reading that currently supports calibration for the AirGradient Go.
To see which configurations are currently available on your cloud (Dashboard) side of your Go. You can take a look at:
http://hw.airgradient.com/sensors/airgradient:SERIALNUMBER/go/config
Replace the SERIALNUMBER with your Go’s serial number.
We will let you know when we have an update on this. Thank you!
This is from my Go’s s/n:
“pmStandard”: “us-aqi”,
“co2CalibrationRequested”: false,
“abcDays”: 1,
“tvocLearningOffset”: 12,
“noxLearningOffset”: 12,
“temperatureUnit”: “c”,
“corrections”: {
“pm02”: {
“correctionAlgorithm”: “custom_via_pm25_raw”,
“slr”: {
“intercept”: -6.864,
“scalingFactorViaPm25”: 2.72314
Can also confirm that my AirGradient Go is also reading about 4C too high compared to my AirGradient One. The AirGradient One temperature is more or less accurate (and agrees with some other sensors that I have), so the Go is definitely reading too high. Humidity is not that far off, about 5-10% lower than the AirGradient One.
Hi @aqiguy, thank you for your reply. In this “corrections” field, it indicates that the correction algorithm for "pm02" (PM2.5) will be applied.
“corrections”: {
“pm02”: {
“slr”: {
While PM2.5 is included, we can see that there is no "atmp" (temperature) or "rhum" (humidity) under this "corrections" field. That is because our current system doesn’t support them yet for the AirGradient Go. You didn’t do anything wrong here. We will give you an update when the Go supports the temperature and humidity correction algorithm. Thank you!
Hi @underwater,
Yes, the AirGradient Go tends to report higher temperature readings, which can be affected by working electronic components.
Please let me check with our team if we have an update on the temperature compensation, and I’ll update you. Thank you!
Just chiming in to say that my Go also reads quite high on the temperature sensor - my One is reading 73.1F and the Go is reading 80.9F, so closer to 5C over-measurement. I understand that there’s going to be some inaccuracy but this strikes me as higher than I’d expect without a warning somewhere.
Not again? You will never learn? Fixable or throw away 259 eur gadget…
Does usbc provide power for extern usb-c fan…=active cooler…
After outdoor Temperature flop…
Hi @Drex, @TeMpL, I hope you are doing well.
Thank you for your feedback. Please let our team look into this and I’ll let you guys know the update. Thank you!
Ok i hope for solution, hw or software… 4.2c at room temperature. Is si simoly not acceptable… +/-0.2=would be ok…
I want to monitor co2 / temperature hunidity… schools and waiting rooms… , cars, busses, train…
Pm is secondary … ad in europe where i live pm pollution is low… and only in 2 m months at evenings durning the winter…
It inaccurate like 3 eur toy… I really thoug you guys leartned something form outdoor unit…
Ut say its prebuild and factory calibrated…
Adding inaccurate temerature to webpage 3 month after payment is a joke…
