Airgrafient Display goes blank even when all options set to ON
Display goes blank, do not have an exact time but usually the next day after a REBOOT.
Display Setting are:
Day Time Brightness = 50%
Night Time Brightness = 30%
Switch off display from 2am to 3am every night to extend the lifetime of the display. = UNCHECKED
Changing these values and saving them does not wake up the display.
Also does not seem to change the setting when Dis[play is ON.
Display values changes only when Power OFF/Power ON is initiated.
Pulling the power from the unit and restarting = Display at configuered brightness
Hi @andrewp, welcome to our community.
The issue you mentioned sounds like a conflict between local configuration (Home Assistant, for example) VS. cloud configuration (AirGradient dashboard).
If that’s the case. You might want to check if the LED brightness in HA is 0 or if there’s an automation set to perform this.
If not, would you mind checking the monitor’s configuration by using a web browser (like Chrome) and access this URL (with your phone/PC connected to the same Wi-Fi as the monitor): http://airgradient_xxxxxxxxxxxx.local/config
Please replace the xxxxxxxxxxxx with your monitor’s serial number.
Myairgradiant came up as esp32c3-025xxx.local.
Response was:
{“country”:“AU”,“pmStandard”:“ugm3”,“ledBarMode”:“co2”,“abcDays”:8,“tvocLearningOffset”:12,“noxLearningOffset”:12,“mqttBrokerUrl”:"",“temperatureUnit”:“c”,“configurationControl”:“both”,“postDataToAirGradient”:true,“ledBarBrightness”:25,“displayBrightness”:50,“offlineMode”:false,“model”:“I-9PSL-DE”,“monitorDisplayCompensatedValues”:false,“disableCloudConnection”:false,“corrections”:{“atmp”:{“correctionAlgorithm”:“none”,“slr”:null},“rhum”:{“correctionAlgorithm”:“none”,“slr”:null}},“httpDomain”:"",“offlineMode”:null,“extendedPmMeasures”:false}
This matches what is setup in: AirGradient
It is the OLED display that goes blank, LEDs are fine.
BTW checking/unchecking “Switch off display from 2am to 3am every night to extend the lifetime of the display.” did not help.
Next time the OLED screen goes blank during the day I am going to do a factory reset.
I do not have Home Assistant or any other automation tool talking to this node.
regards
@andrewp Thank you for providing the info.
Would you mind contacting us via https://www.airgradient.com/support and providing the monitor’s serial number?
Please add a note that it is for me (Tai), I’m happy to help you investigate this issue.
Thank you!
I have done a factory reset to start from scratch.
Will update if the display behaves for a week or so.
Thanks you! Please also feel free to reach out to me if the issue persists.
