I have what seems to be the same, or very similar, problem to:
Airgradient suddenly unable to connect to wifi - AirGradient Forum
I have had my Airgradient for a couple of weeks now. Set-up went smoothly, and all was well.
Today I needed to change my router because my ISP changed. Now, my Airgradient refuses to connect. I set up the same credentials on the new router as the old, and most devices reconnected seamlessly. Not the Airgradient.
I connected to its Wi-Fi hotspot and reconfigured the the Wi-Fi credentials, as I did when I first started. No luck. I have tried several times, in case I mistyped.
I can confirm it is 2.4GHz, and other devices in my home have connected without issue. Neither device has physically moved.
Please help.
