Checkout my solar powered air gradient with 12v battery supply.
Wireless from my house reaches out to the yard.
https://aetrius.dev/2024/03/04/solar-battery-powered-air-gradient-air-quality-monitoring/
Looks good! The voltmeter is a nice touch.
Awesome. Thanks for sharing. We do also have a few AirGradient Open Airs running on solar cells. How many Watts does your panel have and are you sometimes running out of juice?
I’ve only been running this thing for about 12 hours as of this post. I cant remember what the battery started at for it’s initial voltage. I’ll have to watch it charge up to validate.
Est 20% or less used in 12 hours, it dropped about 1 volt for sure, maybe 2.
Assuming I started with a fully charged battery at 12.6V and it’s now at 12.5V, I’ve used approximately 1/12 of the total capacity, which is about 8.33% of the battery’s capacity.
or
if it’s 12.7 V - 1.57% per hour or .79% per hour
This is based on having no solar input as the sun was setting / blocked on the panel through the night.
https://www.amazon.com/dp/B08GX19KT9?ref=ppx_yo2ov_dt_b_product_details&th=1
20W 12V Solar Panel with charge controller
Status update: it’s been fully running through over a month with no issues.
That is great to hear. Thank you very much for sharing. I might have to try to get mine up and running on solar.
nice work! i’ll be trying this out on my new outdoor AirGradient over the weekend
Status update it’s still running super solid. Even two weeks of rain minimal charging she’s got plenty of power
Status update this system has been running solid since March. Air gradient sends alerts if it ever goes offline and it only does that from my Google wifi mesh doing updates.
Super happy with the performance and not running wires everywhere has been great.
I did go back and silicon caulked the battery case and wrapped the cables in a flexible mesh to prevent animals from chomping on cables.
Happy to do a better video /update if anyone ever is interested!
Would love a video update! Highly interested in the wiring detail PLEASE!. Amazing work !
I’ll try to work on that next week when I’m not down with covid!
For now, check this post out I made.
https://www.aetrius.dev/2024/03/04/solar-battery-powered-air-gradient-air-quality-monitoring/
Would love to read it but get:
Please contact web administrator for assistance.
Get well!
Can’t wait to see the new video!
Please bear with me, I ordered a second air gradient, I’m waiting for that to arrive so I can make a second one with a great detailed build video. Any help with getting that asap would be appreciated!
Quick Overview of the wiring diagram. While re-building the solar setup I pretty much had it finished before I decided to rebuild it to encapsulate other ideas and use cases of the solar setup.
v1 Wiring Diagram
<version 2 consists of PCB madness, additional sensors (wind speed, direction), battery voltage, and powering a nest camera> with a breakout board for power distribution. If you guys are curious I’ll show that with the combined v1 setup with air gradient and I plan on feeding data to a prometheus / grafana observability stack.>
Solar & Battery Powered + Air Gradient Air Quality Monitoring – Aetrius Software Engineering - original post should be unblocked - I had all non us blocked but I fixed that too.
@Tyler_Bennet
Thanks for sharing! Good job!
To anyone reading this, you might also want to have a look at our Open Air Max:
https://www.airgradient.com/open-air-max/
