Does anyone use the device without WiFI? I don’t have a 2.4 GHz and it is no connecting to 5 GHz.
Hi @Lana_Koepke, welcome to our community.
I assume that you are referring to the AirGradient ONE (or Open Air), which doesn’t support 5GHz Wi-Fi.
If possible, I would suggest that you enable 2.4GHz Wi-Fi to use the AirGradient air monitor so you can monitor the air quality readings via the AirGradient Dashboard and AirGradient Map (mobile app).
However, if enabling 2.4GHz Wi-Fi is really not an option, and you are fine with running the AirGradient ONE without Wi-Fi and relying on monitoring the display and the LED bar on the physical device, you can use the AirGradient ONE in Offline Mode. Please see: Running the AirGradient ONE in Offline Mode | AirGradient Knowledge Base
Please note that only AirGradient ONE supports running in Offline Mode. The AirGradient Open Air doesn’t have Offline Mode.
