Hello
I am hoping this is just a bad solder or something. I have flashed the firmware and can confirm it is working because I am getting logs out of the microcontroller when it is not slotted onto the board. As soon as I plug it into the board however the device won’t boot. No flash on startup, it doesn’t appear over serial, and it cannot be pinged on the network. I have put the D1 and the sensiron on a breadboard and am able to get readings from it. Troubleshooting so far:
- confirmed SHT3x is not soldered upside down
- confirmed the connections to the sensiron work
- checked the PMS5003 solder to make sure the pads aren’t shorting
- checked the oled solders / wiring to make sure it is correct
- tried with / without the battery hat, with cable plugged in to both the micro usb on that board and the micro usb on the mainboard
PCB is v3.1 so I followed the <3.7 guide. Feeling a little defeated now. Photo attached. I can’t attach the other.
