Is it possible to permanently use the O-1PST Outdoor Monitor indoors? I’m wondering if the default setting of “outdoors” and the correction algorithms only work in an actual outdoor environment and if using it indoors would distort the measurements.
There should be no problem in general. Just keep in mind that the temperature and humidity readings are less accurate on the outdoor model compared to the indoor one.
