Update for update.i_9psl_a_firmware fails on Home Assistant
Good afternoon,
I use several AirGradient ONEs (I-9PSL) connected to the Home Assistant. They all work reliably except for setting a firmware update error few times a day. Was the topic treated already? Thank you very much for help.
The I-9PSL Firmware version is: 3.3.9, Serial number of one of the instruments is: 34b7daa23c68. Configuration ‘Cloud’, firmware ‘Up-to-date.’ The Home Assistant is up to date on Home Assistant Blue / Hardkernel ODROID-N2/N2+.
Could the automatic firmware update be disabled?
The ERROR log in the Home Assistant is as follows:
2025-09-18 13:28:57.147 ERROR (MainThread) [homeassistant.helpers.entity] Update for update.i_9psl_a_firmware fails
Traceback (most recent call last):
File “/usr/local/lib/python3.13/site-packages/airgradient/airgradient.py”, line 62, in _request
response = await self.session.request(
...<4 lines>...
File “/usr/local/lib/python3.13/site-packages/aiohttp/client.py”, line 770, in _request
resp = await handler(req)
File “/usr/local/lib/python3.13/site-packages/aiohttp/client.py”, line 725, in _connect_and_send_request
conn = await self._connector.connect(
    req, traces=traces, timeout=real_timeout
File “/usr/local/lib/python3.13/site-packages/aiohttp/connector.py”, line 642, in connect
proto = await self._create_connection(req, traces, timeout)
File “/usr/local/lib/python3.13/site-packages/aiohttp/connector.py”, line 1209, in _create_connection
_, proto = await self._create_direct_connection(req, traces, timeout)
File “/usr/local/lib/python3.13/site-packages/aiohttp/connector.py”, line 1550, in _create_direct_connection
transp, proto = await self._wrap_create_connection(
...<7 lines>...
File “/usr/local/lib/python3.13/site-packages/aiohttp/connector.py”, line 1268, in _wrap_create_connection
sock = await aiohappyeyeballs.start_connection(
...<6 lines>...
File “/usr/local/lib/python3.13/site-packages/aiohappyeyeballs/impl.py”, line 73, in start_connection
sock = await _connect_sock(
...<6 lines>...
File “/usr/local/lib/python3.13/site-packages/aiohappyeyeballs/impl.py”, line 208, in _connect_sock
await loop.sock_connect(sock, address)
File “/usr/local/lib/python3.13/asyncio/selector_events.py”, line 641, in sock_connect
return await fut
asyncio.exceptions.CancelledError
The above exception was the direct cause of the following exception:
File “/usr/local/lib/python3.13/site-packages/airgradient/airgradient.py”, line 61, in _request
async with asyncio.timeout(self.request_timeout):
File “/usr/local/lib/python3.13/asyncio/timeouts.py”, line 116, in aexit
raise TimeoutError from exc_val
TimeoutError
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 963, in async_update_ha_state
await self.async_device_update()
File “/usr/src/homeassistant/homeassistant/helpers/entity.py”, line 1314, in async_device_update
await self.async_update()
File “/usr/src/homeassistant/homeassistant/components/airgradient/update.py”, line 53, in async_update
await self.coordinator.client.get_latest_firmware_version(
    self.coordinator.serial_number
File “/usr/local/lib/python3.13/site-packages/airgradient/airgradient.py”, line 172, in get_latest_firmware_version
response = await self._request(url)
File “/usr/local/lib/python3.13/site-packages/airgradient/airgradient.py”, line 70, in _request
raise AirGradientConnectionError(msg) from exception
airgradient.exceptions.AirGradientConnectionError: Timeout occurred while connecting to the device
Are you seeing the firmware update error message on the screen of the device, or in Home Assistant, or on the AirGradient dashboard?
You are on the latest firmware right now, 3.3.9
The Error message appears in the Home Assistant.
I also see the errors in HomeAssistant Logs. Device appears to be functional for me, so I think this is cosmetic, but I opened an Issue in the HomeAssistant side:
Logs show AirGradient errors related to firmware update · Issue #152716 · home-assistant/core
Thank you a lot,
I agree that it is a cosmetic but it fills up the log file quite a bit.
Nice day !
I have the same problem.
I get this too… it’s irritating. Please fix it
Any chance of this ever getting fixed?
HA closed the issue saying it’s an Air Gradient integration problem.
