Upcoming Server Maintenance
We will be moving to a more powerful server infrastructure.
Therefore, there will be a planned downtime on Saturday 23. November starting at 00:00 UTC. It is difficult to know exactly how long the server will be down but we expect it to be less than 1 hour.
As a result the IP address of the endpoint where the monitors send data to changes:
Old: 165.22.51.108
New: 128.140.49.53
In case that you have configured this IP address manually in e.g. your firewall then you need to update it.
However, in most cases there is no action required from your side.
One more note, you most likely will need to login again into the dashboard.
Server maintenance has been completed. All systems should be up and running. Please let us know if you notice and issues.
