Trouble with O-1PS
My outdoor device seems to struggle and reboot and eventually fail to reconnect to my wifi. Signal strength should be fine, none of my indoor units have trouble. and it is about 10 feet from an AP through 1 wall made of drywall.
I have reflashed with full erase as of today 2/9/2024
Log file will be in next post because of dumb posting restrictions on both file types and number of images for new users.
Next post containing log data
Does your unit have the TVOC sensor module?
Also this implies that the monitor has some issues connecting to your WiFi network.
Sorry for the slow reply.
It Does have the sensor and was pre-built. My two Version 9 indoor units have no trouble with my wifi.
https://forum.airgradient.com/uploads/default/original/2X/e/e9a74943a961ad9c45a59926d735e9629b7157dd.png
This is some of my wifi info for this device.
Log data
CO2: 664
Post to http://hw.airgradient.com/sensors/airgradient:ecda3b1c6ff0/measures, 200
Watchdog reset
CO2: 664
CO2: 664
Trigger load server configuration
HttpClient get: http://hw.airgradient.com/sensors/airgradient:ecda3b1c6ff0/one/config
Server config: {“country”:“US”,“pmStandard”:“ugm3”,“co2CalibrationRequested”:false,“ledBarTestRequested”:false,“ledBarMode”:“off”,“displayMode”:“on”,“placeOpen”:false,“abcDays”:8,“model”:“O-1PS”}
Server configuration:
inF: true
inUSAQI: false
useRGBLedBar: 0
Model: O-1PS
Mqtt Broker:
CO2: 664
CO2: 664
CO2: 663
CO2: 663
CO2: 663
CO2: 663
inF: true
inUSAQI: false
useRGBLedBar: 0
Model: O-1PS
Mqtt Broker:
CO2: 663
CO2: 663
CO2: 663
CO2: 663
Watchdog reset
CO2: 663
CO2: 663
CO2: 662
inF: true
inUSAQI: false
useRGBLedBar: 0
Model: O-1PS
Mqtt Broker:
CO2: 662
CO2: 663
CO2: 662
CO2: 662
CO2: 662
CO2: 662
inF: true
inUSAQI: false
useRGBLedBar: 0
Model: O-1PS
Mqtt Broker:
CO2: 663
CO2: 663
CO2: 663
Watchdog reset
ESP-ROM:esp32c3-api1-20210207
Build:Feb 7 2021
rst:0x15 (USB_UART_CHIP_RESET),boot:0xc (SPI_FAST_FLASH_BOOT)
Saved PC:0x42055fb6
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd5810,len:0x438
load:0x403cc710,len:0x918
load:0x403ce710,len:0x25f4
entry 0x403cc710
3 2 1
*wm:AutoConnect
*wm:Connecting to SAVED AP: IOT
*wm:connectTimeout not set, ESP waitForConnectResult…
*wm:AutoConnect: FAILED for 3685 ms
*wm:StartAP with SSID: airgradient-ecda3b1c6ff0
*wm:AP IP address: 192.168.4.1
*wm:Starting Web Portal
Build:Feb 7 2021
Saved PC:0x4038c970
SPIWP:0xee
entry 0x403cc710
3 2 1
*wm:AutoConnect
*wm:AutoConnect: SUCCESS
*wm:STA IP Address: 192.168.6.237
WiFi connected!
IP address:
192.168.6.237
inF: true
inUSAQI: false
useRGBLedBar: 0
Model: O-1PS
Mqtt Broker:
CO2: 675
CO2: 675
CO2: 675
CO2: 674
CO2: 674
CO2: 673
CO2: 672
Bumping this as im still having trouble.
Please contact me via the support form on our website and we can then arrange a trouble shooting call and look into this.
