Temperature accuracy?
Hi, I am quite new here and wonder how accurate the temperature readings are. Not far from my house are 2 AirQuality Index stations, which give temperature readings far exceeding the ones from my station. I have also readings from a multimeter temperature probe which are comparable with the AirQuality index stations. On average my station’s readings are 2-3 gr. C. LOWER. I wonder whether others have to same problem and if it can be solved.
Thanks so much for any feedback
What model device do you have? The outdoor one?
Make sure you have the latest firmware on it.
If an indoor model, make sure you are using the stand clips and not laying it on it’s back.
Depending of the topography. Local temperature can varie up to 3°C Maybe more.
Got a Davis Vantage Pro 2 as personnal weather station, air gradient report 2°C less than the Davis
Thank you for your feedback.
Regards, John
