I’m getting strange TVOC measurements with my airgradient indoor monitor (latest model).
To test the TVOC sensor, I first let it run for a week under normal conditions. I got readings that fluctuated between 50 and 150, which seemed correct (given 100 is the baseline value).
Today, I opened a bottle of nail polish near the sensor, and it after a short delay (about a minute) it spiked to 500. After that, I closed the bottle and moved it to a separate room. The sensor read 500 for about 20 minutes, then slowly decreased back to 150 over the course of 7 hours. This is in a reasonably well-ventilated room, with central A/C running. Opening a window nearby did not seem to increase the speed at which the measurement fell.
I tried again about 30 minutes ago with a bottle of acetone (nail polish remover) and got the same result. It’s still at 499.
This seems like erroneous behavior to me. In each case, the concentration of nail polish/acetone in air dropped rapidly after I closed the bottle. I know this because I could no longer smell it, which means the concentration in air couldn’t be more than about 10 ppm (according to Google). It doesn’t seem correct that it would take over 7 hours for that small amount to fully dissipate, especially with a window open for some part of that time. (In contrast, the PM2.5 readings work basically as I expect, and I can get rapid drops by introducing enough ventilation.)
Is this just a quirk of the sensor? I’ve noticed that cheap PM2.5 sensors display a similar “saturation” effect, where they essentially stop functioning properly after being exposed to high (200+) PM2.5 levels. Is a similar things happening here?
Any insight would be appreciated. I would also be curious if others can replicate this behavior.
