Hi,
in my first airgradient setup I am using a PMS5003T sensor.
This sensor has a build-in temperature and humidity sensor.
After integrating this in the software, I can now share the results.
In Grafana I can display both values and are monitoring the average delta of the measurements.
The temperature reading of PMS5003T sensor is 2.9 degrees celcius lower than the SHT31 sensor. The PMS5003T value seems to be close to the actual room temperature.
The humidity reading of PMS5003T sensor is 2.7 percent lower than the SHT31 sensors. I have no value for comparison.
My personal conclusion: using the PMS5003T is more accurate than the SHT31 sensor. The SHT31 sensor is picking up the ambiant heat inside the enclosure.
. Will share ofcourse.
