Rubber band and white plastic pieces came with AirGradient ONE
I purchased an AirGradient ONE and there are items in the package that are not mentioned on the website.
One is a white rubber band. The other two are white plastic pieces that don’t obviously fit anywhere on the case.
Picture: https://imgur.com/a/0JXi2nK
What are these for? Did I mess up the assembly by not putting these inside the unit before closing the case?
The rubber band should have been wrapped around the included USB cable.
The plastic pieces are to make a ‘stand’, they can be clipped into the ventilation slots on the bottom of the case so the unit can be set on a shelf or something similar.
Check out the photo in the middle of this page under “Mounting Options” to see the clips:
Indoor Air Quality Monitor (airgradient.com)
There are also more photos lower in the page showing it standing up for reference
I get it now! Thank you.
I am not able to remove these white standoffs once clicked in.
I have the long part of the clip on the back going into the vents/screw slots, so I kinda pull down the stand on the front so the short part of it isn’t wrapped around the front edge anymore and then kind of wiggle it as I slide it back and it should slide out.
By the way, the rubber band was from the USB C cable.
