I often bring the Pro monitor along when driving between two homes. I find that the D1 board and the Co2 sensor easily pop out of their pin headers. A very minor knock on the case is enough. One then has to unscrew the case, push the D1/co2 sensor back down onto their headers and close the case again. I bet I can put some foam or tape to hold them in place, but I thought I’d mention it here as a possible improvement for future versions.
I can come up with two possible remedies. I bet there are other (better) ideas.
- You could have two holes on the PCB above and below the D1 spot and the CO2 sensor spot. I could then, for example, use a cable tie around the D1/Co2 sensor and tie them to the PCB.
- There could be a spacer in the case mould that physically restricts the D1/co2 boards.
