Pollutant LED Status lights for O-1PST Outdoor monitor
This will be my 2nd year using the outdoor monitor. I bought the kit, assembled and have been quite satisfied thus far.
I have an idea for a project I’d like to implement. While the AG ONE has LEDs that indicate the pollutant level, I would like to add a similar functionality for my outdoor monitor. I am envisioning purchasing and utilizing something like this tricolor industrial warning light
mounted outside near my air sensor, so I can simply look outside and see an indication of PM 2.5.
Has anyone here done something similar? I need to dig into the documentation and decide which design path to take. Perhaps I can directly wire into the monitor and use a canbus chip as a controller. Or maybe I should keep the units separate, use something like a Raspberry Pi, and call the API data to control the light.
I’d appreciate any help or ideas.
Thank you!
Hi @w00dr457, welcome to our community. Sounds like a fun project!
For me, I’d go with the separate unit path as it seems to be easier for me (since I have never worked with the CAN bus, it looks interesting to study and try though).
With a separate unit (like a Raspberry Pi), I think it could give you more flexibility in the project (but also more expensive). The local API of the AirGradient Open Air is easy to work with. You can also set the monitor’s configurations via the local API.
This is what it’s like to GET from the local API endpoints from my AirGradient ONE (the Open Air and the ONE share the same firmware, so the approach is identical):
GET http://airgradient_SERIALNUMBER.local/measures/current
  "pm01": 2.83,
  "pm02": 7.5,
  "pm10": 7.67,
  "pm01Standard": 2.83,
  "pm02Standard": 7.5,
  "pm10Standard": 7.67,
  "pm003Count": 453,
  "pm005Count": 382.67,
  "pm01Count": 72,
  "pm02Count": 5.67,
  "pm50Count": 0.83,
  "pm10Count": 0.83,
  "pm02Compensated": 6.39,
  "atmp": 28.43,
  "atmpCompensated": 28.43,
  "rhum": 58.92,
  "rhumCompensated": 58.92,
  "rco2": 784.33,
  "tvocIndex": 42.58,
  "tvocRaw": 30376.67,
  "noxIndex": 1,
  "noxRaw": 15052.83,
  "boot": 2,
  "bootCount": 2,
  "wifi": -54,
  "ledMode": "co2",
  "serialno": "xxxxxxxxxx",
  "firmware": "3.7.0",
  "model": "I-9PSL"
GET http://airgradient_SERIALNUMBER.local/config
  "country": "TH",
  "pmStandard": "ugm3",
  "ledBarMode": "iaqs",
  "abcDays": 8,
  "tvocLearningOffset": 12,
  "noxLearningOffset": 12,
  "mqttBrokerUrl": "",
  "httpDomain": "",
  "temperatureUnit": "c",
  "disableCloudConnection": false,
  "extendedPmMeasures": false,
  "configurationControl": "local",
  "ledBarBrightness": 100,
  "displayBrightness": 100,
  "offlineMode": false,
  "monitorDisplayCompensatedValues": false,
  "cellOperators": "",
  "cellOperatorId": 0,
  "cellOperatorFailCount": 0,
  "model": "I-9PSL-DE",
  "corrections": {
    "pm02": {
      "correctionAlgorithm": "custom",
      "slr": {
        "intercept": 0,
        "scalingFactor": 0.016522,
        "useEpa2021": true
Here’s the local API documentation for AirGradient ONE and Open Air: firmware-one-openair/docs/local-server.md at master · Open-Air-Foundation/firmware-one-openair · GitHub
Thank you. I ordered an ESP32 development board and will set it up as a separate unit that will use local wifi to make API calls. Some buck converters to transform the voltage and a few MOSFETS for the switching and I should be all set.
My very pleasure. Looking forward to hearing more about how the project goes!
I’ve been tinkering with my new hardware and have been making some progress.
I’m curious about this though, in calling the JSON page, I got back some interesting readings:
{“pm01”:0,“pm02”:0,“pm10”:0,“pm01Standard”:0,“pm02Standard”:0,“pm10Standard”:0,“pm003Count”:54.67,“pm005Count”:47.5,“pm01Count”:9,“pm02Count”:0.5,“atmp”:15.9,“atmpCompensated”:13.66,“rhum”:68,“rhumCompensated”:92.95,“pm02Compensated”:0,“rco2”:452,“tvocIndex”:52.75,“tvocRaw”:33763.08,“noxIndex”:7,“noxRaw”:21915.5,“boot”:12793,“bootCount”:12793,“wifi”:-65,“serialno”:“xxxxxxxxxxx”,“firmware”:“3.7.0”,“model”:“O-1PST”}
The output of the first 6 readings are all 0. Why would that be the case?
Also, there is a large discrepancy between the humidity reading and the compensated amount. Where can I read more about the compensation algorithms?
Hi @w00dr457, hope you are doing well.
These readings are normal when the air monitor is exposed to very clean air. At very low particle concentrations, the sensor can detect some particles while the estimated mass rounds to zero.
You can learn more about the JSON payload here: MQTT Configuration for AirGradient ONE & Open Air via Dashboard | AirGradient Knowledge Base
This article could also be helpful: What Data Is Included in an AirGradient Dashboard CSV Export? | AirGradient Knowledge Base
If your monitor is a DIY Kit, I recommend these articles that can help you improve the PM accuracy by applying a batch-specific correction algorithm:
Please find out more info here: Calibration Algorithms | AirGradient Knowledge Base
This is the slideshow on how the correction algorithm for the Open Air was developed: https://www.airgradient.com/documents/webinars/AirGradient_Webinar_Temperature_and_RH_Correction_MAR2024.pdf
It could be a long read, but I hope it answers your questions. Please feel free to let me know if there’s anything else you want to know.
Good day!
