I just got my AG One kit (10.02.2025). After assembly all worked OK. Then I tried including it into HA and still OK. Then I moved to HA OS and flashed with MallocArray ESPHome definition and I really like it but after boot PMS was only showing NaN. Never wake up although I hear its fan working.
I tried several things:
- repeat flashing with MallocArray definition
- reflash with stock firmware (several times); with and without device cleaning
- reflash with Android software (3.2.0)
- checked PMS cable and connectors
- tried different USB cable and charger
None of the above helped. During boot on stock firmware I always get “Sensor init Error: PMS not found” and displayed value is “0” or “-”.
There is also something wrong with LEDs: rightmost green is always ON. Leftmost purple/yellow/white is ON sometimes, CO2 level is on LEDs 3-6 from left (starting abt 1500 ppm), LEDs 2 & 7-10 never lights up; LEDs 7-11 don’t react for LED test.
Current firmware is 3.1.21.
Can you please help with this or suggest what else can I try?
