Hi!
I just purchased a kit and set it up with the default instructions for 4.2. Once it started up, I noticed that the PM value is always -1.
I’ve tried to do some debugging by testing the cable wiring voltage against the ground which seems to give the correct voltage of 5v,0v,0v,3.3v,3.3v starting from the red wire on the cable. Attached photos to show this.
The rest of the sensors seem to be fine with co2 and temperature. Would folks be able to help debug? I’ll also continue investigating.
