[EDIT - SOLVED - I removed a solder bridge between pins 5 and 6 of the PMS5003 cable socket, this some how solved the problem despite not being connected to anything.]
The PM2.5 is reading -1 on my DIY AirGradient Pro, PCB v 3.7. The dashboard doesn’t report a value at all. I have tried installing the software manually through the Aurdino IDE as well as through the web browser.
I also have a presoldered AirGradient Pro, PCB v 3.7 that I put together back in May. So I’ve done some testing as follows.
Kit 1
- May D 1 Mini
- Dec PCB
- Dec PM2.5
Result: PM: -1
Kit 2
- May D 1 Mini
- Dec PCB
- Dec PM2.5
Result: PM: -1
Kit 3
- Dec D 1 Mini
- May PCB
- May PM2.5
Result: PM: 9-11
Kit 4
- Dec D 1 Mini
- Dec PCB
- May PM2.5
Result: PM: -1
Kit 5
- May D 1 Mini
- May PCB
- Dec PM2.5
Result: PM: 6-9
I have tested the DEC PCB and have connectivity from the left most pin to VCC, the second leftmost pin to GND, the 4th to D6 and the 5th to D5.
