Upgraded but the S8 sensor doesn’t seem to be recognized…
ESP-ROM:esp32c3-api1-20210207
Build:Feb 7 2021
rst:0x15 (USB_UART_CHIP_RESET),boot:0xc (SPI_FAST_FLASH_BOOT)
Saved PC:0x4038bfda
SPIWP:0xee
mode:DIO, clock div:1
load:0x3fcd5810,len:0x438
load:0x403cc710,len:0x91c
load:0x403ce710,len:0x25b0
entry 0x403cc710
E (198) esp_core_dump_flash: No core dump partition found!
E (199) esp_core_dump_flash: No core dump partition found!
Serial nr: ecda3b1d98a8
Firmware Version: 3.0.6
Firmware Mode: FW_MODE_PST
Server configuration:
inF: true
inUSAQI: false
useRGBLedBar: 2
Model: O-1PP
Mqtt Broker:
S8 calib period: -1
*wm:AutoConnect
*wm:Connecting to SAVED AP: duick
*wm:connectTimeout not set, ESP waitForConnectResult...
E (2800) wifi:Association refused temporarily, comeback time 1004 mSec
E (3809) wifi:Association refused temporarily, comeback time 1004 mSec
*wm:AutoConnect: SUCCESS
*wm:STA IP Address: 192.168.10.105
Webserver init: airgradient_ecda3b1d98a8.local
Post payload: {"wifi":-37,"boot":0}
Get server config: {"country":"US","pmStandard":"ugm3","co2CalibrationRequested":false,"ledBarTestRequested":false,"ledBarMode":"co2","displayMode":"on","placeOpen":false,"abcDays":8,"model":"O-1PP"}
inF: true
inUSAQI: false
useRGBLedBar: 2
Model: O-1PP
Mqtt Broker:
S8 calib period: 8
inF: true
inUSAQI: false
useRGBLedBar: 2
Model: O-1PP
Mqtt Broker:
S8 calib period: 8
abcDays config: 8 days(192 hours)
Current config: 192 (hours)
set 'abcDays' ignored
CO2 index: 866
[1] PMS0.1: 0
[1] PMS2.5: 1
[1] PMS10.0: 1
[1]PMS3.0 Count: 327
[1] Temperature: 22.52
[1] Humidity: 56
TVOC index: 0
TVOC raw index: 30391
NOx index: 0
TVOC index: 0
TVOC raw index: 30416
NOx index: 0
I originally connected the PM and CO2 sensors to the opposite connections and there was an error in the log reporting an issue. I opened up the unit and swapped the connectors and while the unit is now reporting the PM and TVOC/NOx measurements I’m not seeing any CO2 measurements.
Any ideas?
