MQTT and TLS fails with "esp-tls-mbedtls: No server verification option"
Hi,
I’m trying to connect my stock firmware 3.1.4 Airgradient ONE, to a cloud MQTT server (hivemq), but it looks like there is some issue with TLS:
[MqttClient] Info: Init uri: mqtts://username:password@some-id-here.s1.eu.hivemq.cloud:8883
Other event id:7
Connect to MQTT broker successful
Delete old MQTT task
Create new MQTT task
E (1391467) esp-tls-mbedtls: No server verification option set in esp_tls_cfg_t structure. Check esp_tls API reference
E (1391467) esp-tls-mbedtls: Failed to set client configurations, returned [0x8017] (ESP_ERR_MBEDTLS_SSL_SETUP_FAILED)
E (1391584) esp-tls: create_ssl_handle failed
E (1391632) esp-tls: Failed to open new connection
E (1391686) TRANSPORT_BASE: Failed to open a new connection
E (1391751) MQTT_CLIENT: Error transport connect
MQTT_EVENT_ERROR
[MqttClient] Error: Reported from esp-tls: 32791
[MqttClient] Error: Reported from tls stack: 0
[MqttClient] Error: Captured as transport's socket errno: 0
[MqttClient] Info: MQTT_EVENT_DISCONNECTED
[MqttClient] Warning: Connection failed count 1
Is MQTT over TLS supposed to work in the stock firmware?
(I’m quite new to airgradient, sorry?) is the stock firmware open source (are these the source - GitHub - airgradienthq/arduino when I flash from AirGradient ONE (I-9PSL) and Open Air (O-1PST) Firmware Versions)?
Thank you for reporting. We need to test this particular case.
Can you please raise an issue on our github for this:
And yes, these are the correct links to the firmware version. One is the compiled version of the GitHub repository.
yes, sure, I actually got it running by patching and compiling locally, to provide the root certificate in esp_mqtt_client_config_t.cert_pem:
 openssl s_client -connect uuid.s1.eu.hivemq.cloud:8883 -showcerts < /dev/null | sed -ne '/-BEGIN CERTIFICATE-/,/-END CERTIFICATE-/p' > trust.crt
# take the first/root certificate only
 cat trust.crt | head -n $(cat trust.crt | grep -n 'END CERT' | head -n1 | cut -d ':' -f1) > ca.crt
xxd -i ca.crt > src/ca_trust.h
# manually add a 0x00 termination in ca/ca_trsut.h and the following changes
git diff
diff --git a/src/MqttClient.cpp b/src/MqttClient.cpp
index 66c71e6..df19248 100644
--- a/src/MqttClient.cpp
+++ b/src/MqttClient.cpp
@@ -15,6 +15,8 @@ MqttClient::MqttClient(Stream &debugLog) : PrintLog(debugLog, "MqttClient") {
 #endif
+#include "./ca_trust.h" // unsigned char ca_crt[] // xxd -i ca.crt > src/ca_trust.h
 MqttClient::~MqttClient() {}
 bool MqttClient::begin(String uri) {
@@ -31,9 +33,11 @@ bool MqttClient::begin(String uri) {
   logInfo("Init uri: " + uri);
 #ifdef ESP32
   /** config esp_mqtt client */
   esp_mqtt_client_config_t config = {
       .uri = this->uri.c_str(),
+      .cert_pem = (const char *)ca_crt,
   /** init client */
@@ -283,6 +287,8 @@ static void __mqtt_event_handler(void *handler_args, esp_event_base_t base,
   esp_mqtt_event_handle_t event = (esp_mqtt_event_handle_t)event_data;
   esp_mqtt_client_handle_t client = event->client;
+  mqtt->logInfo("Event id: " + String(event_id));
   int msg_id;
   switch ((esp_mqtt_event_id_t)event_id) {
   case MQTT_EVENT_CONNECTED:
