Monitor airflow
Does anyone knows if i can add this sensor to the amazing airgradient monitor?
i need to monitor the airflow in a few rooms, as some co-workers complains about a draft, and i therefor need some data on it, to force the leadership to acknowledge that there is a problem.
It needs 9v which we cannot provide from the board directly so you would need a step up converter or an external 9v power source.
Thanks for the reply.
I guess that there is no other hardware, that match the criteria for the board you use.
