Measurement values for the AirGradient One TVOC readings?
Hi all. Just got my airgradient and new to the discussion. I was similarly disappointed to see how TVOC measurements are handled.
The ENS160 does report an absolute TVOC measurement in ppb by processing their raw sensor data, though they’re also doing some similar baselining and calibration under the hood. Nonetheless, the result is far more useful. I’ve sent an email to ask for more details.
I’m not really convinced by the argument that a MOX sensor fundamentally can’t be used for absolute measurements. It’s a solvable engineering problem. But maybe the cost doesn’t make sense for the markets/margins.
NOx is an interesting one because the dedicated sensors seem to be very expensive ($130+ for an analog sensor that still needs analog processing and an ADC). There is a much cheaper sensor made by Spec Sensors, but it doesn’t seem to correlate well, or even at all, to proper field measurements (see field evaluation by AQMD)
So in this case the index seems to be the best you can do. It’s also more helpful that the index starts at 1, but not having a scale on the measurement makes it somewhat useless as well.
The ind40 values under the analytics page are based on the 0-500 index. However, the ind30 values are Sensirion’s previous measurements (shown in ppb) and these are also visible on the dashboard. You can read more here:
As you can see, these ind30 values go far higher than 500 (please ignore my intermittent data, this monitor moves around a lot with me!).
Turns out they are doing a baseline operation on the output that would negate any long term VOC emissions in the measurements.
Is this for the ind30 or ind40 measurement?
What are the ind30 values exactly? ppb ethanol equivalents? Are they measured exactly without any baseline correction?
I notice my VOC measurement goes up when my force air propane furnace runs - went from 27 at 7am with furnace off all night to 450 after a few hours of having it turning on every half hour or so to heat the house.
Sounds reasonable, propane is a (V)VOC (see Technical Overview of Volatile Organic Compounds | US EPA) so it should be detected. Probably the furnace does not burn 100% of the fuel, so you should expect an increase in VOC. Did the measurements for NOx increase as well?
Hello, I m bumping the thread to ask if there is a way to request the reset of the VOC baseline like it is possible to do for the CO2. I would like to monitor a place that I suspect to be polluted long term and I think it would be helpful to be able to take my sensor out for few minutes and reset the base level instead of having to wait for a full averaging period.
Check out the .pdf posted.
The TVOC level you get is relative to the last 24 hrs. of monitoring.
So, if you’ve had it running for 24+ hrs and then you get a spike in the TVOC level, you know that something in the environment is causing the spike.
Do you know if we can reset it to a baseline?
scenario
  • Room was empty for couple of days. Naturally, VOC levels will drop.
  • Room is now occupied. TVOC reading show ~400.
My assumption is that because the previous 24 hours was so low due to the room not being occupied, that simply occupying it caused a significant increase (reading of 400), where in reality, if the room stayed occupied the whole time, the reading might be close to 100.
I understand the sensor is relative, and read Achim’s post on this, but I’m trying to understand how harmful this spike is.
Thanks
In the Dashboard, under General Settings>Calibration you can change the interval for TVOC learning offset, but it is either the default of 12 hours or longer
https://app.airgradient.com/settings/place?tab=1
You can restart your device by pulling power to reset it somewhat, but if VOC had been stable over the last 24 hours, it should have been around 100. A jump up to 400 would indicate a significant change in the level of VOCs, not just because it is occupied. An increase of CO2 levels would account for people being present.
Have you cooked any food, opened nail polish or alcohol based air freshener or anything like that?
500 is the max it will report, so 400 is pretty high, so I would crack a window and run some vent fans if you have them.
I have a home occupied all night and day and my VOC is currently showing 115. When we cook, it goes maybe to 200, but one painting session and it goes 400+
Thank you for your reply.
Sounds like I have a mysterious voc source I need to track down :frowning:
Do you know of good voc purifiers? I’ve heard activated coconut carbon is best, but amount seems hard to find.
Trying to understand the ind30 measurement based off the discussion above… is ind30 an absolute measurement since it is measured in ppb? Or is it still a relative measurement like ind40?
Ind30 is actually the official conversion of the Sensirion VOC gas index to a RESET Air approved absolute number in ppb. We honestly think that this conversion does not make much sense and that indicating it as ppb creates a lot of confusion (this is why we avoid labeling it as ppb).
However some of our customers are using these building standards and thus we have it implemented as an optional number.
Confused? You can read the details here:
Hello, is the 720h learning offset still useful if automatic updates are enabled? As I understand it, the baseline resets after every reboot.
Hi @Achim_AirGradient, I have an outdoor AirGradient air quality monitor, and two indoor AirGradient monitors.
Is it possible to use the average of the outdoor monitor as the baseline for the indoor monitors?
Assuming that the outdoor VOCs are relatively stable, using the outdoor average would offer a fixed baseline for the indoor sensor to be computed against, rather than using the 24 hour average from indoor measurements as the baseline.
I’ll often see indoor and outdoor sensors measuring roughly the same VOC levels, but when I open a window, the indoor measurement drops to near 0. This is a clear indication that the indoor sensors have just adjusted their relative offset according to a high VOC baseline inside.
This is an interesting idea and something worth looking into.
While it depends on the composition of VOCs, it’s common for the concentration to increase at daytime due to photochemical reactions and temperature-dependent emissions (both light and higher temperatures can lead to a higher concentration of VOCs). However, I am not sure of the absolute difference this causes in concentration - especially outdoors. Perhaps we could use a longer baseline period on the outdoor device (7+ days) to account for these diurnal patterns and set a better baseline for the indoor comparison.
Cool idea! I will look more into this and see if it’s something we can introduce.
Awesome, thanks!
I was curious about fluctuations in outdoor VOCs given your description on how photochemical reactions and temperature impact concentration, and found that there are indeed diurnal fluctuations. However, I suspect my sensor data is heavily impacted by the VOC learning offset I had, which was set to only 12 hours until recently. Nevertheless, if you think that data would be useful, I’d be happy to share the ~1 year of historic data I have.
Cheers
Thank you for your comment. I am trying to find a monitor that will measure VOCs, including acute change in VOC. I’m noticing a bad smell at certain times of the day and I want to see if the VOC level changes. Can I use the air gradient for that? Sounds like the TVOC measurement is not the right one to use for this, but I’m trying to learn.
Hi @Please, welcome to our community!
This question is honestly tough to answer. It depends on what causes the ‘smell’. If it’s a VOC, then the monitor should be able to notice the change. If it’s not a VOC, then the monitor might not see anything.
To learn more about VOC, these articles could be helpful to start with:
