My Senseair somehow managed to get miscalibrated - values when taken outside were hovering around 1400 and inside were in the 1700s. I didn’t have much luck with the manual calibration using the Ground pin, what did work is the manual calibration sketch example from the S8_UART library.  (The RX and TX pin for the AirGradient are 2,0).
   To do a manual calibration
#include <Arduino.h>
#include "s8_uart.h"
/* BEGIN CONFIGURATION */
#define DEBUG_BAUDRATE 115200
#if (defined USE_SOFTWARE_SERIAL || defined ARDUINO_ARCH_RP2040)
  #define S8_RX_PIN 2        // Rx pin which the S8 Tx pin is attached to (change if it is needed)
  #define S8_TX_PIN 0         // Tx pin which the S8 Rx pin is attached to (change if it is needed)
#else
  #define S8_UART_PORT  1     // Change UART port if it is needed
#endif
#define COUNTDOWN (6*60)      // Time in seconds to wait outside before a manual calibration starts
/* END CONFIGURATION */
#ifdef USE_SOFTWARE_SERIAL
  SoftwareSerial S8_serial(S8_RX_PIN, S8_TX_PIN);
#else
  #if defined(ARDUINO_ARCH_RP2040)
    REDIRECT_STDOUT_TO(Serial)    // to use printf (Serial.printf not supported)
    UART S8_serial(S8_TX_PIN, S8_RX_PIN, NC, NC);
  #else
    HardwareSerial S8_serial(S8_UART_PORT);
  #endif
#endif
S8_UART *sensor_S8;
S8_sensor sensor;
void setup() {
  // Configure serial port, we need it for debug
  Serial.begin(DEBUG_BAUDRATE);
  // Wait port is open or timeout
  int i = 0;
  while (!Serial && i < 50) {
    delay(10);
    i++;
  // First message, we are alive
  Serial.println("");
  Serial.println("Init");
  // Initialize S8 sensor
  S8_serial.begin(S8_BAUDRATE);
  sensor_S8 = new S8_UART(S8_serial);
  // Check if S8 is available
  sensor_S8->get_firmware_version(sensor.firm_version);
  int len = strlen(sensor.firm_version);
  if (len == 0) {
      Serial.println("SenseAir S8 CO2 sensor not found!");
      while (1) { delay(1); };
  // Show basic S8 sensor info
  Serial.println(">>> SenseAir S8 NDIR CO2 sensor <<<");
  printf("Firmware version: %s\n", sensor.firm_version);
  sensor.sensor_id = sensor_S8->get_sensor_ID();
  Serial.print("Sensor ID: 0x"); printIntToHex(sensor.sensor_id, 4); Serial.println("");
  // Countdown waiting outside
  Serial.println("Now, you put the sensor outside and wait.");
  Serial.println("Countdown begins...");
  unsigned int seconds = COUNTDOWN;
  while (seconds > 0) {
    printf("Time remaining: %d minutes %d seconds\n", seconds / 60, seconds % 60);
    delay(1000);
    seconds--;
  Serial.println("Time reamining: 0 minutes 0 seconds");
  // Start manual calibration
  Serial.println("Starting manual calibration...");
  if (!sensor_S8->manual_calibration()) {
    Serial.println("Error setting manual calibration!");
    while (1) { delay(10); }
void loop() {
  static unsigned int elapsed = 0;
  // Wait 2 sec lamp cycle
  delay(2000);
  elapsed += 2;
  // Check if background calibration is finished
  sensor.ack = sensor_S8->get_acknowledgement();
  if (sensor.ack & S8_MASK_CO2_BACKGROUND_CALIBRATION) {
    printf("Manual calibration is finished. Elapsed: %u seconds\n", elapsed);
  } else {
    Serial.println("Doing manual calibration...");
I plugged the USB into a laptop and took the sensor outside, the serial showed a 6 minute countdown at the end of which the sensor calibrated.
