Loaded Software - Unable to test example BLINK
I have loaded the software to the ESP8266.
I have selected the Lolin Wemos D1 Mini Pro on multiple USB ports.
When trying to run the BLINK test I get the below error.
Arduino: 1.8.19 (Windows Store 1.8.57.0) (Windows 10), Board: “LOLIN(WEMOS) D1 mini Pro, 80 MHz, Flash, Disabled (new aborts on oom), Disabled, All SSL ciphers (most compatible), 32KB cache + 32KB IRAM (balanced), Use pgm_read macros for IRAM/PROGMEM, 16MB (FS:14MB OTA:~1019KB), v2 Lower Memory, Disabled, None, Only Sketch, 921600”
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -dump-prefs -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\REDACTED\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\REDACTED\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\REDACTED\Desktop\Environment\libraries -fqbn=esp8266:esp8266:d1_mini_pro:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=16M14M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\REDACTED\AppData\Local\Temp\arduino_build_246034 -warnings=all -build-cache C:\Users\REDACTED\AppData\Local\Temp\arduino_cache_508489 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mklittlefs.path=C:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs.path=C:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=C:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\tools\python3\3.7.2-post1 -verbose C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\examples\01.Basics\Blink\Blink.ino
C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\arduino-builder -compile -logger=machine -hardware C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware -hardware C:\Users\REDACTED\Documents\ArduinoData\packages -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\tools-builder -tools C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\hardware\tools\avr -tools C:\Users\REDACTED\Documents\ArduinoData\packages -built-in-libraries C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\libraries -libraries C:\Users\REDACTED\Desktop\Environment\libraries -fqbn=esp8266:esp8266:d1_mini_pro:xtal=80,vt=flash,exception=disabled,stacksmash=disabled,ssl=all,mmu=3232,non32xfer=fast,eesz=16M14M,ip=lm2f,dbg=Disabled,lvl=None____,wipe=none,baud=921600 -vid-pid=1A86_7523 -ide-version=10819 -build-path C:\Users\REDACTED\AppData\Local\Temp\arduino_build_246034 -warnings=all -build-cache C:\Users\REDACTED\AppData\Local\Temp\arduino_cache_508489 -prefs=build.warn_data_percentage=75 -prefs=runtime.tools.mklittlefs.path=C:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mklittlefs-3.0.4-gcc10.3-1757bed.path=C:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\tools\mklittlefs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc.path=C:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.xtensa-lx106-elf-gcc-3.0.4-gcc10.3-1757bed.path=C:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs.path=C:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.mkspiffs-3.0.4-gcc10.3-1757bed.path=C:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\tools\mkspiffs\3.0.4-gcc10.3-1757bed -prefs=runtime.tools.python3.path=C:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\tools\python3\3.7.2-post1 -prefs=runtime.tools.python3-3.7.2-post1.path=C:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\tools\python3\3.7.2-post1 -verbose C:\Program Files\WindowsApps\ArduinoLLC.ArduinoIDE_1.8.57.0_x86__mdqgnx93n4wtt\examples\01.Basics\Blink\Blink.ino
Using board ‘d1_mini_pro’ from platform in folder: C:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2
Using core ‘esp8266’ from platform in folder: C:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2
Detecting libraries used…
“C:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed/bin/xtensa-lx106-elf-g++” -D__ets__ -DICACHE_FLASH -U__STRICT_ANSI__ -D_GNU_SOURCE “-IC:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/include” “-IC:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/lwip2/include” “-IC:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2/tools/sdk/libc/xtensa-lx106-elf/include” “-IC:\Users\REDACTED\AppData\Local\Temp\arduino_build_246034/core” -c -w -Werror=return-type -Os -g -free -fipa-pta -mlongcalls -mtext-section-literals -fno-rtti -falign-functions=4 -std=gnu++17 -ffunction-sections -fdata-sections -fno-exceptions -DMMU_IRAM_SIZE=0x8000 -DMMU_ICACHE_SIZE=0x8000 -w -x c++ -E -CC -DNONOSDK22x_190703=1 -DF_CPU=80000000L -DLWIP_OPEN_SRC -DTCP_MSS=536 -DLWIP_FEATURES=1 -DLWIP_IPV6=0 -DARDUINO=10819 -DARDUINO_ESP8266_WEMOS_D1MINIPRO -DARDUINO_ARCH_ESP8266 “-DARDUINO_BOARD=“ESP8266_WEMOS_D1MINIPRO”” -DFLASHMODE_DIO -DESP8266 “-IC:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266” “-IC:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\variants\d1_mini” “C:\Users\REDACTED\AppData\Local\Temp\arduino_build_246034\sketch\Blink.ino.cpp” -o nul
Alternatives for bits/cpu_defines.h: []
ResolveLibrary(bits/cpu_defines.h)
→ candidates: []
In file included from c:\users\REDACTED\documents\arduinodata\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed\xtensa-lx106-elf\include\c++\10.3.0\cstdlib:41,
from c:\users\REDACTED\documents\arduinodata\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed\xtensa-lx106-elf\include\c++\10.3.0\stdlib.h:36,
from C:\Users\REDACTED\Documents\ArduinoData\packages\esp8266\hardware\esp8266\3.0.2\cores\esp8266/Arduino.h:27,
from C:\Users\REDACTED\AppData\Local\Temp\arduino_build_246034\sketch\Blink.ino.cpp:1:
c:\users\REDACTED\documents\arduinodata\packages\esp8266\tools\xtensa-lx106-elf-gcc\3.0.4-gcc10.3-1757bed\xtensa-lx106-elf\include\c++\10.3.0\xtensa-lx106-elf\bits\c++config.h:525:10: fatal error: bits/cpu_defines.h: No such file or directory
525 | #include <bits/cpu_defines.h>
compilation terminated.
exit status 1
Error compiling for board LOLIN(WEMOS) D1 mini Pro.
Any ideas?
Cheers
Dan
have you checked to see if bits/cpu_defines.h is actually when it’s expected to be?
Hey Indymx
The package I loaded and trying to test is from here
I would have thought even though the package loaded with no errors, there is no mention of changing any file elements.
Thoughts?
