I purchased an AirGradient ONE in late 2023. It has worked without issue until yesterday. I moved the unit to a new location to get some air quality readings and when reviewing the data in homeassistant, I noticed that the PM readings were suspiciously low (PM0.3 in the low hundreds, PM1, 2.5, 10 at zero).
I don’t have another PM sensor to compare against, so I’ve left the sensor outside for a few hours. It still consistently shows much lower readings than it has for the last ~1.5 years.
The model#/serial on the outside of the unit reads: PMS5003-2023081102183 which I believe predates the current calibration issues. Though for what it’s worth, I have tried changing the calibration values in the dashboard to no avail.
Is this a known failure mode with these sensors? or is it a software issue? I don’t wish to spend the ~$40 on a new sensor unless it’s completely necessary.
Thanks in advance.
