The humidity on my Airgradient One display is no longer matching what the relative humidity is reporting in the dashboard.
For example, right now the humidity on the display is reporting 63% whereas the dashboard is reporting 45%. I think the dashboard is correct based off other humidity sensors I have.
This only started a few days ago, maybe after a firmware update.
Is this a known issue? How can I fix this?
EDIT: it also seems like the other measurements are starting to drift, although not as drastic as the RH. For example, on the dashboard I have: Co2 809 ppm, Temperature 68.36 degF
Meanwhile on the display: Co2 852 ppm, Temperature 65.7 degF
