How to remove the feets ? It seem to be stuck inside and impossible to remove.
Just use gentle wiggle…
A gentle wiggle as suggested, but the foot also slides to lock in place at the back of the monitor.
After various struggles, I found the simplest and easiest way to remove the foot is:
Lay the monitor on its back
Gently push the front of the foot away so that it clears the case
Holding the foot back, gently push downwards. (towards the rear of the case)
The foot should now slide out
(Don’t force ./ bend the foot too much, it only needs a little pressure)
Once you get the hang of it, it’s actually quite easy
