How to Make AirGradient ONE Data Public on the AirGradient Map?
Is it possible to make the AirGradient ONE data public so it appears on the AirGradient map?
I plan to place the monitor on an outdoor balcony at my home. If so, what steps are required to enable this feature if possible? Thank you!
In the Dashboard, go to the menu>Hardware>click three dots under Action column>select Edit Location
Here you can set “Include in reporting”
Thank you for the response. What I mean is being able to operate the AirGradient ONE Indoor as if it were an AirGradient Open Air (Outdoor) and make the data public in the map.
Oh, I don’t think that would be an appropriate use, as it would skew the map. The map is intended to be the Outdoor CO2 levels. Indoors your CO2 could get very high, my bedroom hits 2000 ppm at night, and inside the house can hover around 1000 with multiple people.
If your sensor started showing that on the public maps, it would appear as if your area has outdoor CO2 levels in the thousands, which is not representative of the outdoor levels that it is intended to show.
Ok I understand, but like I said, the monitor will be placed in the balcony of the house in the outdoor.
Thanks
