How to integrate 5ghz?
Has anyone get their airgradient one’s to work on 5ghz? If so, how did you go about it?
AirGradient devices do not support 5 GHz Wi-Fi.
Most routers allow you to enable dual-band networks (2.4 GHz + 5 GHz), and in some cases AirGradient devices can connect successfully even when band steering is enabled.
Can you tell us more about your WiFi setup?
The chip used only supports 2.4 Ghz
Espressif Centralized Documentation Platform (CDP) | Espressif Documentation
