I noticed recently that my I-9PSL is no longer reporting into Home Assistant. I also have 3x DIY Pro and those are working fine. The issue seems to have occurred around Oct 15th.
The error it gives is: “Failed setup, will retry: An error occurred while communicating with the Airgradient device: Unable to parse AirGradient response”
If I try to re-add it with the same IP it says “Failed to connect”
I can see data in the AirGradient Dashboard normally.
Also I am able to browse to the device directly and get the measurements:
http://192.168.X.X/measures/current
{“pm01”:0,“pm02”:0,“pm10”:1.33,“pm01Standard”:0,“pm02Standard”:0,“pm10Standard”:1.33,“pm003Count”:176.83,“pm005Count”:107,“pm01Count”:0,“pm02Count”:0,“pm50Count”:0,“pm10Count”:0,“pm02Compensated”:0,“atmp”:28.47,“atmpCompensated”:28.47,“rhum”:35.56,“rhumCompensated”:35.56,“rco2”:529.67,“tvocIndex”:100,“tvocRaw”:32907.42,“noxIndex”:1,“noxRaw”:16298.33,“boot”:16,“bootCount”:16,“wifi”:-64,“ledMode”:“co2”,“serialno”:“abc123”,“firmware”:“3.7.0”,“model”:“I-9PSL”}
I also tried downgrading the firmware to 3.6.2 but same issue:
{“pm01”:0,“pm02”:0,“pm10”:0.5,“pm01Standard”:0,“pm02Standard”:0,“pm10Standard”:0.5,“pm003Count”:166.5,“pm005Count”:97.5,“pm01Count”:0,“pm02Count”:0,“pm50Count”:0,“pm10Count”:0,“pm02Compensated”:0,“atmp”:28.31,“atmpCompensated”:28.31,“rhum”:36.53,“rhumCompensated”:36.53,“rco2”:618,“tvocIndex”:108.92,“tvocRaw”:33118.83,“noxIndex”:1,“noxRaw”:16990.33,“boot”:5,“bootCount”:5,“wifi”:-64,“ledMode”:“co2”,“serialno”:“abc123”,“firmware”:“3.6.2”,“model”:“I-9PSL”}
