I attempted following the steps to add air gradient indoor monitor to home assistant, but air gradient is not listed as an option when trying to add new integration. I’m on 3.1.13
In most cases, if the AirGradient is on the same network as Home assistant, it will automatically be detected.
You’ve already setup the new device and it is connected to the AirGradient dashboard? It this a new device?
What version of HomeAssistant?
Moved HA to my pi 5 from a VM and it started working. Not sure what the issue was.
