Error when adding to home assistant
I just unboxed and set up my airgradient, to be honest, its been a bit of a nightmare. After a few hours getting it on wifi, i finally was able to add it to my IOT wifi (same network home assistant is on). Home assistant picked it up immediately asking to ignore or add. Clicking add , it says “Do you want to set up I-9PSL?” I click submit and after about 30 seconds I get an error “Unknown error occurred”
looking through forums , ive seen people talk about bridge mode, multiple networks, etc. Both home assistant and AirGradient are on the same network.
Does anyone have an idea?
Hi. Will it work when you manually add it by IP address via AirGradient integration?
Thanks Tai in the end, i rebooted the home assistant PC and it worked.
Glad you made it. Enjoy your ONE!
