I noticed all 3 of my DIY Pro sensors running ESPHome on Home Assistant were reporting unusually high temp by around 15 F and lower humidity. Red area in picture. I looked at a History graph in Home Assistant and noticed this change happened last week, probably around the time I did an update. But the Logs in HA don’t go that far back so I can’t confirm the exact versions. However this morning I did update to ESPHome 2023.9.3 for all sensors.
Also today I took off the rear case from one of my sensors (Guest Room) and have it right next to 2 other temp monitors but its still reporting high. You can see when I take off the lid as the reading gets more noisy. Green in picture.
Anyone else with ESPHome notice the same with the 2023.9.x series of updates?
This and another ThermoPro sensor are reporting 80F but with the DIY Pro rear lid off its reporting 90F
