DIY Pro (pre-solder) not showing up as USB device (Macos)
Assembled the unit, it boots up fine, seems to work, etc. I want to switch it to ESPHome, but I don’t get a serial device and don’t see it with ioreg
Macos 13.4, and I installed all the serial drivers from the website, any other tips to try?
The USB-C port on the circuit board only provides power, it does not do data.
Connect a Micro-USB directly to the D1 mini and then you should be able to discover it.
