I have an original DIY-Pro-Kit-Pre-Soldered
ESP8266
etc.
It has always given me trouble with rebooting randomly.
I want to finally deal with it.
First I disconnected everything except the temp/humidity & screen (but also disabled all code except temp/humidity).
[insert cool image, new users can’t post more than 1 embedded, /sad]
Ran fine.
So I added the Senseair S8
And it reset.
Took a lot longer…but still.
I am now testing a ESP32 based D1 Mini to see if it related to the ESP8266 D1 (bad batch) or something else.
My question is something like this:
- What are my options at this point?
- I see there are 9+ versions now?
- There are now new display locations so which ones are compatible with my PCB and/or case?
- Should I order a new PCB with the new fancy things?
- Can I just add huge capacitors to the circuit (seems to me like it is power related).
- Or is it related to the traces/PCB (IIRC something about that in the forums when the new versions got started).
- What ESPHome firmware should I be running now? (I always had issues getting publishing my results to the Air Gradient website, Home Assistant works just fine tho.)
Disclaimer:
Achim is always so helpful. I believe in the mission and want to help.
I wanted to leverage the community and am willing to fund whatever changes personally.
IE Not a support request.
